Alltanator
rick heisler
Alltanator
Just wondering if I can still uses the wiring from the original 292 generator on a new alternator ?Or will this be a problem and are they still wire red the same? thanks for any help with this guys.
in a nutshell, no.
there are differences in wiring and in the voltage regulators.
you can however put in a GM style 1 wire alternator easily. this is against my religious persuasion (use only Ford parts) but does work well from what i have heard.
- Uncle Skip
rick heisler
ford alternator info. the 1G uses external regulator.
http://fordfuelinjection.com/?p=63
1963 uni PATINA BLUE
1965 short bed
1965 short bed
fmartin_gila
- Uncle Skip
motormount1
MOTOR MOUNT
about 5 or 6 years ago i bought a one wire altonator for one of my tractors. i sold this tractor the new owner fixed the generator that came on the tractor and reinstalled it he gave me back my one wire. i put it on my 64 and got rid of alot of wires under the hood. it works perfectly.and i dont have all those wires.less crap that could go wrong. ive had as many as 3 slicks at one time. ive had things go wrong that should have not gone wrong,but they did.
rick heisler
motormount1
motormount1
motormount
you also can get a altonater for a 79 chevy that has a internal voltage regulator. get the plug that gose in it from auto zone. hook the wire that says battery on it to the post on the back of the alt.and from the post on the alt run a 10 gauge wire.the othere wire on the plug run back into the cab.get a 12 volt light that you can hook up ungrounded. tie the wire in you ran back into the cab in to one of the 2 wiers on the ungrounded light the other wire hook to somthing unfused that turns on and off with the key switch.just make sure that what ever you hook to is positve current. i did this to my 73 ford i had in high school and it lasted till i sold it 4 or 5 years later.
