gear box????
rick heisler
gear box????
Post by rick heisler »
I TALKED TO THE PREVEUSS OWNER AND HE TOLD ME HE PUT A 1TON GEARBOX IN MY 64 4BY4 NOW IS THIS A BIGGER GEARBOX THAN THE ORIGANAL GEAR BOX?HE SAID IT WAS TO HELP STEER BETTER.IM HOPING THE ORGANAL IS SMALLER SO THE EX MANNIFOLD ON THE 429 DOSNT HIT THE GEAR BOX.
61-66 F350 ,61-65 f100 4x4 and 61-66 f250 4x4 all use the same gearbox. the 61-64 2wd f100 and f250 box is not interchangeable with the 4x4, f350 box.
pics
4x4, f350 column/gearbox
[albumimg]1602[/albumimg]
although they look similar, there is a big difference in bolt pattern, gearing and size.
[albumimg]1603[/albumimg]
rick heisler
YA THE ONE IN MY TRUCK IS THE F350 THE SPLINE THAT COMES OUT THREW THE FRAME IS HUGE AND YOU CAN SEE WHERE HE CUT THE HOLE BIGGER IN THE FRAM I GUESS I NEED TO GO TO THE PARTS WANTTED AND START LOOKING FOR THE RIGHT ONE.
i remember in chat a few weeks ago someone (Dean or Ken ?) mentioned you had an f600 box which is way too big. i have the correct box for you. i could also cut out a frame repair piece if necessary.
rick heisler
HOW MUCH FOR THE BOX?AND ILL SEND YOU A MONEY ORDER I HAVE A OLD FRAME FOR THE PEICE I NEED
