flexplate part
- dotcentral
flexplate part
I have a 71 short bed that I want to install a 351W and AOD. Originally it was a 302/3 speed manual. I thought I had all the parts, but start flipping through the HP small block book and see "be sure to install a load spreader ring between block and flexplate" I don't have one. My limited experience with transmissions has been with manuals, so I got a dumb question. Does the AOD have a load spreader ring? Is it the same as the C4 version? I might find a C4 load spreader ring in my various piles of parts, but know I don't have the AOD version. Is this a Ford only part, or would somewhere else carry it? My guess is I need one, and it's something I need to get from a dealer or junk yard.
- FORDMANLCRACKEL
A picture is worth a thousand words. Its the light brown circle ( in the pic )that the flex plate bolts go through. It helps with spreading of the clamping force of the bolts.
http://cgi.ebay.com/ebaymotors/89-92-Pr ... dZViewItem
Lonnie
Lonnie
