At first I didnt realize it was a unibody, but the grill was the same as my 62, which made no sense since the box matched the cab. then i finally noticed there was no seam whatsoever between box and cab heh.
I know nothing about unis, I've read around here you folks talking about them, but to be honest I'd never seen one til today. Its sitting off in the bushes a bit, looks like it hasnt been run since around 1970, and the back is full of garbage. It does however appear to be all there, (couldnt tell without climbing over the fence) with the exception of having a replacement hood from some unknown donor slick. All the glass is good etc from what I can see.
The odd part is that it had 8 lug wheels. (this time I checked both axles heh)
Did they make 3/4 ton unis?
Are unis valuable?
what makes them so desirable?
Are they rare or have I just never noticed them?
Whats a non-running but all there uni worth?
and most importantly....
Should I try and convince this guy to give up the truck to me?
I've been googling round trying to find info on unis, but no real luck so far as far as history goes.
