gas tank under bed?
snopek
gas tank under bed?
Post by snopek »
looking to buy a tank to mount under my bed. i would like at least a 16 gal. what tanks do you use and where did you get them? also do you use the stock fule pump or put in electric ones? let me know thanks!
picks would be awesome too
Uncle Skip
Post by Uncle Skip »
There are more options here than you can shake a 14" 1/2 drive extension at.
I did an article for Custom Classic Trucks about putting in a 22 gallon Mustang tank between the rear frame rails, and I'm pretty sure the link is on the forum somewhere.
Since then, several more guys have stepped up with their own ideas and every one of them is and example of forward thinking and great craftmanship.
I chose the 22 gallon tank because it was the largest capacity I could find that would physically fit under my truck.
More than a few have used my basic idea and improved on it as far as the location of the filler.
I'm sure Max and a few thers will chime in and show you pictures so you get the basic idea.
But be warned, what ever route you take, you need to have a little more than basic construction skills and tools.
[albumimg]7488[/albumimg]
[albumimg]7487[/albumimg]
[albumimg]7489[/albumimg]
If you can't find my article, let me know and I'll see if I can post you a link to look at.
And let me know if I can help.
Uncle Skip
fire truck
Post by fire truck »
I put a tank from a rodeo under the bed of my truck, one day I'll do a write up on it...
Ding Dong! oh that's just me chiming in! :lol:
I put a Mitsubishi Pagero tank in mine, holds 90 ltr and comes with a in tank pump if your going fuel injection.
[img][img]http://i533.photobucket.com/albums/ee33 ... 4_0066.jpg[/img][/img]
snopek
Post by snopek »
i can still use my factory fule pump right? just have to fab up the fule line on the bottom ?
Thats right!
BobbyFord
Post by BobbyFord »
Here's a link to the Mustang tank that I put in my '72 short bed:
http://www.fordification.com/forum/view ... &sk=t&sd=a
PFM-64f100
Post by PFM-64f100 »
This is my bronco II tank for my crew cab. The filler hose is upside down it does route over the frame rail. This is a 23 Gal tank, they do have a 33 gal tank option to go with. You can get it in EFI or Carb version.
Easy install just move that rear brace to the back of the frame and flip it upside down. stops it from interfering wtih styleside beds and adds a little more protection.
Rusty 63
Post by Rusty 63 »
Chris: what years are the bronco2 tanks? & which are fuel injected? Thanks!
