Decisions, decisions...
Today, I bought a '66 shortbed that has a 5.0 efi and auto tranny out of a 1989 Lincoln Towncar. (80,000miles on both) The truck came with the wiring & ecm from the Lincoln plus instructions on how to wire it up to the F100.
The frame has been sandblasted and painted black, paint is partially stripped from the cab, good fenders, extra radiator support, extra radiator, repair panels for the one cab corner with rust through (the only place that has rust through), all glass, original radio, dash unmolested, headliner, two ac condensors, no bed or rear bumper.
My problem? Do I want to finish this truck with this power plant, sell the engine/tranny and install my 300 w. Warner T-18, or sell the truck as-is? I have my '65 F100 longbed that I just got in running condition, so do not need this '66. But, it is never a questions of need, is it?
I will take some photos and post them tomorrow.
Jake
Jake
- ezernut9mm
Re: Decisions, decisions...
azjake wrote: I will take some photos and post them tomorrow.
Jake
you'd better. lol
sounds pretty good jake. no matter which direction you go it sounds like a winner.
Jake,
It looks it a fine project, Have you heard the 5.0 run? Do you know the condition of the auto trans? I would vote for the 300/T18 but I am a old stick in the mud simple carburetor and points (well maybe a pertronix) guy myself. Just my
as much as i do not care for later engines, if most of the work is done and you have all the parts to finish and the time/desire to mess with electroncs it might be the way to go.
myself i would sell the engine and put the 300 in.
BarnieTrk,
That's what I think, too!
Obsa,
The PO was building this truck for his wife and seemed to be doing everything right. He told me the engine and tranny were fine and that he ran the engine & checked the tranny before he pulled them from the Town Car. They have 80,000 miles on them.
His divorce was finalized Monday so he is selling everything & moving outta state.
deviant1,
No way will I cannibalize my '65 to get this F100 running! All parts are here (except gaskets for the glass) to get this thing running. It will mostly just take time.
Ice,
If I keep this truck, I will probably install the 300 & T-18 I have from another '66 F100. I do not care for EFI since I do not have the knowledge to keep it running. Now, a good 4bbl would be nice on thei engine, but I would not be able to use the transmission that is with it.
Jake
Obsa,
deviant1,
Ice,
Jake
- Uncle Skip
http://fordfuelinjection.com/
It's really not that hard once you know how it works. It's not too tough to learn either.
Agreed. It can be a pain sometimes but once it's properly tuned and working well the driveability can't be beat. All the vacuum hoses and emissions components can be troublesome, but I think a lot of it can be eliminated. Replace the O2 sensors while the engine is out and you should be okay later on. The EFI harness comes out as a complete unit, so as long as the harness hasn't been butchered it should pretty much be plug and play.
The Crown Vic/Town Car/Grand Marquis engines are tuned for low-end torque so it should make for a nice daily driver. Especially with the AOD. 80,000 miles is nothing on these engines.
Just out of curiousity though, why wouldn't you be able to use the AOD if you switched to a carb? I don't think it's electronically shifted. I think all you need is a proper throttle valve cable kit.
Greg D,
Thanks for the link. The PO did give me a book titled "How to understand, service & modify Ford fuel injection & electronic engine control" for 1988-1993 Ford, Lincoln & Mercury cars and light trucks by Charles O. Probst. I will research the book and the website you provided before I make a decision. But, you know what they say about old dogs...
The Big M,
You are probably correct. I thought that the transmission was electronically controlled. But, I am not that up with the newer engines/transmissions, so am probably wrong. Now, give me a good 4bbl carb and a 4 speed...
Jake
The Big M,
Jake
It looks a lot better than my rusty 63!!! Sweet deal. I'd run w/ the 5.0 until it craps out & then swap in the six... it looks like you've got the room....
Not sure what happened to this post so I fixed it...
Well, after much thought and deliberating back & forth, I have decided to sell this '66 F100. With everything else going on in my life right now, I do not need this project.
BTW, it does have the steering column, spindles, rotors and disc brake calipers for it from a '72 Ford.
If anyone is interested. please contact me. I am asking $1,500.00, but feel free to make an offer.
Jake
Jake
Well, no one has bought this '66 F100, or even made an offer on it, so I am keeping it.
Today, I made a deal with a guy for freshly overhauled 302 engine & C6 tranny out of a mid '70s Ford. I am trading the 5.0EFI, E4OD tranny, wiring harness and ECM for his engine & tranny. Plus, he is removing my engine/tranny and installing his in my truck. Even trade. I will be taking my truck to him in the next few days.
I am not very knowledable when it comes to EFI or electronic ignition, but I can work on a carbed engine. So, it is a good trade to me.
Jake
Jake
I hear ya, Jake. I'm in the same boat.
The EFI stuff doesn't interest me and as a result I know very little about how it works and I have no desire to learn it.
This wrenching on old trucks stuff is supposed to be fun, not work.
I think you made a good deal.
I hope the fella does ya right with the install....
BarnieTrk
BarnieTrk
Remember, that 89 5.0 is SPEED DENSITY and not MAF equipped, so if you plan on any performance mods it will need to be converted to MAF. I have the exact same engine I just pulled from an 89. I plan to ditch the EFI and install my 3x2 carb setup and a set of Edelbrock heads and keep it more old school. If you need EFI parts, this one has some new stuff on it I will let go of cheap. I have the entire setup as far as anything on the engine, but no harness or computer. I was too lazy to pull it off the car when I had it here.
TxSlick66
aka MustangSteve
Money you ENJOY wasting is NOT wasted money...
aka MustangSteve
