Got my new engine built
Well, the shortblock, anyways....It's a 390 HD ribbed truck block, bored .060" over, flat top pistons, 280H Comp Cam, double roller chain/gears, HV oil pump, '68 390 heads, Comp Cams valvetrain, (springs, retainers, keepers, pushrods) old Edelbrock S427 dual plane intake with a 600 Holley. Hedman headers. Gotta put the heads and top end together and install this Spring in my '65 F100 Custom Cab. Looking forward to replacing the tired 352 with this!!! Should be fun!!!!
Congrats, sounds like a fun mill.
Re: Got my new engine built
Sounds nice!notdunyet wrote:Well, the shortblock, anyways....It's a 390 HD ribbed truck block, bored .060" over, flat top pistons, 280H Comp Cam, double roller chain/gears, HV oil pump, '68 390 heads, Comp Cams valvetrain, (springs, retainers, keepers, pushrods) old Edelbrock S427 dual plane intake with a 600 Holley. Hedman headers. Gotta put the heads and top end together and install this Spring in my '65 F100 Custom Cab. Looking forward to replacing the tired 352 with this!!! Should be fun!!!!
What compression ratio do you figure you'll have - under 10:1 for regular gasoline?
Do you plan to run a Pertronix ignition?
BarnieTrk
got my engine built
Thanks! I'm looking forward to it!!! Should be a good runner!!
Got my engine built
I should have between 10-10.5 C.R. the way it sits. I doubt it'll run well on 93 octane...not worried though...I work at the airport all day in Grand Rapids, and we happen to sell 100 LL.....Hehehehe....and it smells like the dragstrip when it burns!!! Plus, I get it at a discount!
I run my 428 on 91 all day long and im at 10.5 to 1 comp just cant run the timing the way id like
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
c-6 wide ratio modified
torino front stub
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
