I'm starting to think about what my wheel/tire combination will be on my '66 F-100 lwb. I think I'd like to keep the stock hubcaps but run a little larger tire in the back with a 15x8 wheel. I'd keep the stock wheels in the front. What Wheel Vintique wheel should I choose for the back. Is 4" the offset to use? I was considering using a P27560R15 tire on the rear. What size would look good on a stock front wheel?
In the future I am also thinking of lowering the truck with either a DJM or AIM kit. Would using the larger tire in the rear cause a clearance issue if I lower the truck?
Wheel/Tire Help Please
Troublemaker427
Jody Aberts
Troublemaker2
1966 Fairlane 427
AA/NSS
9:22@143
1964 Galaxie 500XL
390 p-code 4spd.
1966 F-100
390-C6
Troublemaker2
1966 Fairlane 427
AA/NSS
9:22@143
1964 Galaxie 500XL
390 p-code 4spd.
1966 F-100
390-C6
- Gary Seymour
The Wheel Vintique "Gennie" series is supposed to work with the stock hubcaps. I've talked with WV on the phone because that is the exact type of wheel I wanted to use on my truck, and still may go that route with the stock caps when the truck is closer to being finished.
4" offset will be fine with P27560R15 tire. Stock is 3 3/4".
Currently I have P27560R15 BFG Radial T/A's mounted on 15x8 Crager V-series (cheap!) wheels, 3-3/4" offset, and I have an inch clearance from the back of the tire to the inside of the wheelwell, and about the same to the fender lip.
You can get the Gennies bare (primed) or powder coated in a variety of colors.
- Gary Seymour
I have 225x60s on 7s on the front, 275x60s on 8s on the rear - 15" wheels stock backspacing (4"?). With these sizes I'd recommend a 1/4" spacer on the rear - raised letters rub the inside of the wheel house when the axle is angled. Mine is pretty low - about 1 1/4" to the bumpstops on both ends.
Here are pics to show you how they fit, on a Uni anyway.
- Gary Seymour
Troublemaker427
Yes, thats me from the FE forum. I have all kinds of FE projects....lolwinr wrote:Hey Troublemaker427.
My 8" rear wheels are centered in the rear wheel well wity 4.5 back space.
8" rear wheels with 4 " backspace had them closer to the inside than the outside.
65 F-100 short wide.
Are you on the FE forums ??
Ricky.
Thanks to everyone for their input.
Jody Aberts
Troublemaker2
1966 Fairlane 427
AA/NSS
9:22@143
1964 Galaxie 500XL
390 p-code 4spd.
1966 F-100
390-C6
Troublemaker2
1966 Fairlane 427
AA/NSS
9:22@143
1964 Galaxie 500XL
390 p-code 4spd.
1966 F-100
390-C6
Troublemaker427
http://www.summitracing.com/parts/WVI-1 ... /?rtype=10
This looks like the wheel I'll go with for the rear.
Jody Aberts
Troublemaker2
1966 Fairlane 427
AA/NSS
9:22@143
1964 Galaxie 500XL
390 p-code 4spd.
1966 F-100
390-C6
Troublemaker2
1966 Fairlane 427
AA/NSS
9:22@143
1964 Galaxie 500XL
390 p-code 4spd.
1966 F-100
390-C6
