points or pertronix
- slickmainer
points or pertronix
I was wanting to get a feel for the need of having points. Im new to this so forgive me in my most basic of questions. I saw points being changed once and I only recall someone saying "now don't do this" followed by a laugh. Is this a worthwhile upgrade? how long to points last? Is there something better than the ignitor 2 without spending $100s
--Gregg--
you can't get there from here
- Uncle Skip
- slickmainer
i will keep my points.
simple ,inexpensive and easily changed.
been doing them so long i can eyeball the gap close enough for the engine to run.
i check mine with the dwell meter when i change my oil and reset if necessary. i only buy USA made standard blue streak points and ignition components.generally i can get a couple years out of a set depending on how many miles are driven.
cost prohibits carrying a spare new pertronix in the glovebox,so most people i know with pertronix keep a set of points in the box in case they need a roadside repair as pertronix are not readily available in the parts stores.
points do require a bit more maintenance to ensure they gap is correct but to me its not an issue.
now i sit back and let the rest of the folks tell me how i am stuck with ancient technology and i should "upgrade".
fact is i have had the pertronix on an engine and noticed no improvement over the points other than not needing to check the gap/dwell.
- charliemccraney
I'd go with points over Pertronix because of the availability issue. What engine are you running? You might be able to simply swap a duraspark II from the junk yard. It'll cost less than $100. With Duraspark, you can get replacement parts at any parts store. Upgraded Duraspark will eat Pertronix for lunch.
- slickmainer
I respect and value both that replied so thank you. honestly I don't know what my new one comes with, so i was just asking. Is there a how to anywhere for changing the points safely?
240 and T18 4sp
240 and T18 4sp
--Gregg--
only safety related thing regarding changing points is make sure the key is off. that way you are not making sparks close to the carburetor.slickmainer wrote:I respect and value both that replied so thank you. honestly I don't know what my new one comes with, so i was just asking. Is there a how to anywhere for changing the points safely?
240 and T18 4sp
Petronix, will make the engine run like a totally different engine. Unbelievable how much better it runs. This is what I run now on all my y blocks. Won't mess with a set of points again unless forced to. Occasionaly I run points as I don't want to spend the money to convert, if I'm selling the truck.
- bobenhotep
if yer runnin a 240 get a dsII and a HEI module.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
flareside64
You can keep an extra Pertronix dizzy module in the glove box too, I do - only takes up the same space as the points.
- ezernut9mm
i will do pertronix on my 66 and 70 when i get around to affording them. i had it on my 68 360 and it was dead nuts reliable.
My choices are, in order of preference: 1, dura spark distrubiter with MSD controller box and E coil. 2, dura spark distrubiter with stock controller box and E coil. Points as a last resort. As you can see I don't like stock coils, E coils are more reliable and provide a hotter spark. To convert most Ford distrubiters to magnetic pickup is too easy and elemanates all the messing around with points and I have had only one duraspark box fail me ever. The E coil needs a 12 volt switiched power source not the reduced voltage from the ignition switch
For a 240, a straight DSII distributor swapped in from a 70's 300 wouldl be an excellent upgrade. Then spend $15 for an extra module in the glove box and you will have reliablility AND performace.
For me, to keep original appearances, I went with a Pertronix Ignotor II.
One person asked about Ignitor I versus Ignitor II.
I favor the Ignitor II. It has a variable dwell, which gives slightly better high RPM performance. BUT, more importantly, the Ignitor II has overload protection, so if you leave the switch on, it won't burn up. The Ignitor I will *sometimes* cook itself if you leave the switch on.
