What's can I use off of a 79 on my 65?
I've got a 79 F-100 long bed that I am going to be parting out. Other than the disc brakes and master cylinder, what can I use on my slick? The 79 is a I6/3 on the tree.
- Truckfarmer
Well I'm not lucky enough to have one with power steering or brakes. So far all of the things listed I don't need. Figures don't it! The column is no better that the one in the 65 and I already have a rebuilt 302 waiting to go in.
How similar are the wiring harnesses? The one in the 65 is sketchy at best. Does anyone know if the fuel tank out of the 79 will fit the 65's frame?
My 302 is a 79 model. Will the bellhousing of the 3 speed bolt up? What about the 65's 3 speed?
Thanks for the help.
- Johnny Canuck
My '64 has a lot of dentside (73-79) parts in it.
Engine,
steering column,
rear end,
Duraspark,
Horn relay,
Horn,
wiring harness,
starter switch,
windshield wiper delay switch,
windsheild wiper motor,
door light switches,
trans cross member,
brake proportioning valve,
power steering pump,
gas filler door
could have used the seat but didn't
could have used transmission but didn't,
Sent engine perches to another member who used them
sent exhaust manifolds to another member who used them
Gave the twin I beam set up to a friend who used it on his '67
Gave the brake booster /MC set up to a friend who used it on his '67
Gave the steering box to a friend who used it on his '67
plus
sold a pile of parts on ebay
Engine,
steering column,
rear end,
Duraspark,
Horn relay,
Horn,
wiring harness,
starter switch,
trans cross member,
gas filler door
plus
