C6 Crossmember?
Posted: April 16, 2010, 2:23 pm
by azjake
My '66 shortbed has a 302 and C6 sitting in place. However, the transmission is setting on a piece of square tubing used as a spacer to get the correct driveshaft angle. I would like to know if there is a commercially available crossmember made to install the C6 in my '66 F100 shortbed?
Thanks all.
Jake
Posted: April 16, 2010, 4:29 pm
by azjake
Or, is there an adapter available I can use to mount the C6 to the factory crossmember?
Jake
Posted: April 16, 2010, 5:55 pm
by Garbz
The 302 is mounted to high on the incorrect perches.
Common mistake.
Garbz
Posted: April 16, 2010, 6:20 pm
by azjake
Thanks for the info. Since I didn't install these, I am trying to figure this out. What engine perches do I need and where do I get them?
Jake
Posted: April 16, 2010, 8:27 pm
by 52elwood
Hi,
You need to find perches from the early model truck that came with an 302.
Junk yard is where I found them and they bolt right in.
Posted: April 16, 2010, 8:45 pm
by banjopicker66
It is also possible that you have the correct perches, but they are bolted into the wrong holes.
With the correct perches in the correct holes, a C-6 behind an FE and a different C-6 behind a 460 all bolted properly onto the same stock original crossmember in my Slick that came with a 3 speed.
Posted: April 25, 2010, 7:41 pm
by 66camperspecial
I used the original crossmember when installing the 460/C-6 in my 66 but had to drill holes farther back.
Posted: April 25, 2010, 8:03 pm
by Fordman
the perches yo uneed are in 69-79 2wd trucks. they mount in the front holes of the crossmember. the back set of holes is for the fe and 460 only. the front set is for 302 and 6 cyl only.
