What carb do I have and where can I get a rebuild kit?
truckster
Post by truckster »
What can you tell me about this carburetor? is it worth rebuilding? or do you guys have any suggestions on where to get a good rebuilt one already? maybe a different one like a holley? im all ears...
thanks
http://fordtruk.com/forums/album_pic.ph ... er_id=2133
truckster
Post by truckster »
might help if i tell you it's a 1964 with a 223
olliesshop
Post by olliesshop »
I would think it's worth rebuilding to keep it original, assuming it's original, since it looks different than my '61 carb. Although, you'll probably sacrifice some fuel economy with it.
Alternatives:
• This site would probably have some good advice ... http://www.fordsix.com/forum/viewtopic. ... 50&start=0
• Or you could go the tried and true Clifford Performance route ... http://www.cliffordperformance.net/Merc ... _Code=F223
Just some thoughts. Hope it helps. :D
Tim - 1961 F250 Uni
292fan
Post by 292fan »
Looks like you have the tried and trued Autolite 1100. I got one for my rebuild kit for mine on my Falcon at my local Napa parts store. That carb was used on a lot of the sixes up to the 70's. Hope this helps.
dotcentral
Post by dotcentral »
Pony carbs has a good reputation. Not cheap though.
http://www.ponycarburetors.com/default. ... tolite1100
