vin data plates
557f1
vin data plates
Post by 557f1 »
Hi,does anybody know if you can buy new vin data plates,
i've managed to lose mine in the shed somewhere.stupid thing!
FORDBOYpete
Post by FORDBOYpete »
557F1: There are several companies with rights granted to them by FOMOCO & US Govt. They are listed in Hemmings Motor news.
I deal with the company in Lake Havasu AZ who's name I would need to look up @ my shop & post for you later. I'm away from shop right now. I'll try to do it later today, it will be after 1800- 1830 EDST & get back to you.
They had best Quality & Best Price I found. They require a photo copy of title or legitimate registration & name on it must match who they send the replacement too, or at least they did last time I bought a Data Plate From them, it was maybe 2005 -'06 or so. I believe it cost me under U$ 30.oo with mailing etc. in the USA.
FBp
Change is the Only Constant
65Lover
Post by 65Lover »
I know nothing about these people, Haven't used them, but here is a link
http://www.datatags.com/
Ruth
'65 F-100 Custom Cab SB Styleside
'67 Ford Mustang FB
'68 Mercury Cougar
Slickstock Altoona Iowa
Slickstock Salina Kansas
557f1
Post by 557f1 »
Thanks guy's ,i had a better look in my shed and found the plate ,but it will need some work so i will try the tag restorers,
Hawkrod
Post by Hawkrod »
You are now worse off than before, that is not a Ford tag! Hawkrod
557f1
Post by 557f1 »
it came on my truck and i found some id numbers on another site and the 41424 is a f100 6cyl,4 speed,ute back 1964,
i tried datatags and they haven't seen one like this and don't do resto's on tags.they only make new ones,
http://www.fordforums.com.au/showthread.php?t=77535
Hawkrod
Post by Hawkrod »
557f1 wrote:it came on my truck and i found some id numbers on another site and the 41424 is a f100 6cyl,4 speed,ute back 1964,
Oh, I missed the location, that is probably a local tag for a knock down assembly. Sorry, Hawkrod
64Ranger
Post by 64Ranger »
I have used http://www.datatags.com/ and was very happy with the product.
Doug
Riverside, CA
Uncle Skip
Post by Uncle Skip »
Actually, someone should make this a sticky in the "How To" forum.
It's bound to come up again.
U@ss
557f1
Post by 557f1 »
Hawrod,that's ok,
i will give datatags another go and see if they will make a new tag for me
it's strange how they use different tags on the same item,
ezernut9mm
Sweden
Post by ezernut9mm »
i see smclaren is over there as well (pun intended). he is a regular over on the fordification site as well.
