65 F100 4x4 parts truck turns project
- F7BIGJOB
After is on ebay again
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
-Steve
Re: After is on ebay again
F7BIGJOB wrote:http://cgi.ebay.com/ebaymotors/1966-Ford-F-250-Highboy-Pickup-/180655193895?pt=US_Cars_Trucks&hash=item2a0fe37f27
that thing just sold @ B-J auction in January! for 11,000 something i think
Thanks Steve great post I aim to try and duplicate that truck on the F100 chassis.Yours is one of the best flairsides Ive seen. That limer is one of the best little fb Ive seen. Just trying to get the 65 on the road by end of summer as a DD. Thanks urquidezp I did post a question on that over on FTE in the bigblock motor form and yourself and a few others agree it is done for weight and size issues. I had never seen that before. I disassembled alot of motors when I was in highschool working in my dads automotive machine shop dont ever recall seeing a rod like that.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
1965 F100 4x4x352
1998 F150 4x4x4.6
Hey Bill the only things that jumped out at me as being incorrect where the door arm rests and the steering column and the steering wheel. Other than the bed unless it was a from the factory fb.Pics didnt show much of the mechanicals. Nice ride though Ill be glad if mine comes out looking half as nice seeing as where its starting from.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
The weather finally got nice in these parts. Its been raining and cold after work most nights so havent done much on the 65. I did a little on it tonight
Parts is parts and pieces is pieces. I think this is a factory spare tire mounting bracket. It will go on the 63
The white bed from the 63 will temp to the 65 until im ready to get it in the garage. With the bed off the 63 frame Ill go to work on that frame.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
I had a few minutes over the weekend and did a little on the 65
Put some wheels and tires on it from an 80s f that my neigbor was parting some good rubber for cheap just till she is up and running better than those worn out splits.
Also got the rest of the rusted out bed and rear bumper cut off quite a difference between a 65 F100 4x4 and a 66.
Got the heater and gas tank removed. Heater needs a little more cleaning and repaint then reinstall. Gas tank was scrap it was rusted out. Will clean rust inhibit the cab then reinstall the tank with a good one.
Just a few of the way it sits now with the bed floor removed as well as the rear bumper. Quite a bit of difference between 65 F100 4x4 and 66. Ford made alot of changes in 66.
I was getting up close and personal with the front frame with a 4 1/2 angle grinder and wire wheel of course it started to rain so only got this far. I was hoping to get the whole frame done. When the frame is all cleaned por and painted I will move the white box from the 63 to this frame temporarily so the 63 frame can be worked. I can then work the 63 box from where it sits on the 65 frame. Who knows may make the 63 into the flatbed and keep the 65 with a good cab and box.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
- slickmainer
You got that right Gregg. So far Ive had to clean off the driveway about 4 times. Im pretty sure Ive moved about 30lbs of good Idaho top soil to our gardens. It took about 45 minutes just to get all the dirt that was packed into the cab corners and front kick panel wells washed out. Well worth the effort though. Its actually in alot better shape than I thought it was when I bought it.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
HiBoy63 wrote:You got that right Gregg. So far Ive had to clean off the driveway about 4 times. Im pretty sure Ive moved about 30lbs of good Idaho top soil to our gardens. It took about 45 minutes just to get all the dirt that was packed into the cab corners and front kick panel wells washed out. Well worth the effort though. Its actually in alot better shape than I thought it was when I bought it.
HiBoy, Do you have an adequate air supply? If so I could drop by with my blaster and clean that up in minutes...
Steamer also. The only 2 pieces of equip I have access to.
I do have a compressor but not big enough to run air tools for any length of time. Always glad to have you stop by and blast away on this mess anytime Randy. Dont think my air supply will handle what you got thought. You might get claustrophobia in my cramped work space thought.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
I got a few hours of free time this weekend. I managed to get the front frame completly cleaned and Por 15ed. Por was a gloss black now i will rattle can a rustolem satin over that. This again is kind of a quick hitter so I can get back to work on the 63.
Next will be to clean and regasket and paint this motor. And get it installed.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
Spent a couple hours last night cleaned and painted the heater box and air intake duct.
Before
After
Took the blower motor apart cleaned and blew it out it was siezed reoiled the bearing packing that was bone dry. Runs fine now just have to sand the outside of it a bit and then paint. Evaporust for the rubber housing and metal insert thats rusted.
Painted the heater housing and duct with pasticoat vinal paint.
Pull and save front bumper for $12 and a rear stock bumper for $5 at the early Ford V8 swap meet. Both need to be straightened front needs a rechrome and the rear chromed.
Next three things to do will be get the motor cleaned and installed and freshen up the interior and get the gauges and seat and gas tank back in.
Before
After
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
Worked on a few things this weekend. Painted the front frame with satin rustoleum paint. Cleaned and degreased the 352 and painted it. Finished painting the blower motor for the heater.
I also need to thank my son for all the help on the prep for painting this weekend.
Next time I get some time I will be regasketing the motor with new pan timing cover oil filter,carb and valve cover gaskets. It will be time to clean and install the gauges and spruce up the interior and por the floor. Have to get some hedders ordered so when the motor is back together we can set her in and fire her up. Oh better put the gas tank I got from Backyard resto in too.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
Got a little more done on Saturday. With my 4 1/2 grinder I ground my cup wire brush down to the nubbins so had to stop. Ill get another brush today and finish the frame.
Interior floor wire brushed and ready for sealing. Got a few tin worm holes to deal with when it gets a body off resto.
Wire brushing the frame till there was nothing left of the brush. Harbor frieght today then back to work.
Well off to harbor freight then back to work. Have a nice Sunday.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
Finished cleaning the frame and started the por15ing inside cab and rear frame section.
To this point I have only used 3/4 of a quart.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
Finished the por15 on the rear frame section and the rear end.
A quart can made it all the way. Need to get another for the bed and colateral stuff. Started stripping and priming bed for the 63. I will store it on the frame of the 65 until it gets a place in the garage.
Started prep on the dash to paint it duplicolor rattle can wimbeldon white. The steering column and pedals will be rustoleum black gloss.
Ordered a set of hedders from sumitt racing for the FE. Should see those in a few days. When the hedders get here Ill finish putting the motor back together and installing the dual pot mc. Then hang the motor in her and start putting the sheetmetal back on the front.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
