Alan Mclennan wrote:Leith, that pic shows exactly the problem area!, Ben at TPUP was helpful with the kit it self but was a bit vague as to what wheel and back-offset he used!, are you going to use one?
As I said before the slick from the image had 17x7 on the front.
I'm guessing the steering geometry would be the same or very similar to the EL, so anything that will fit the EL should be ok. Trouble is, the EL GT had the biggest wheel from the factory and it was 17"
I'd reckon you are going to be stuck with something 17" or something waaaay bigger aka 20"+ to clear the Upper control arm.
Did u get the PM?
