I bought a NOS voltage regulator of e-bay.
it is for a 71 but the numbers are the same.
It buzzes and the alt light comes on.
How can I check this regulator.
Thank You!
Voltage regulator
- Blackwaterforge
Voltage regulator
rick heisler
buzzing is indicative of the points inside malfunctioning.
probably sounds like an electric train transformer?
if it has a removable cover i would look inside.
i can look up the test on the manual later but my guess is its 40 years old and may have gotten moisture in it or stored in a humid place.could have bounced off a shelf, those things are sensitive to a lot of things.
much as i like to keep original parts the electronic voltage regulators used on the mid 70s up are an upgrade.
My orignal 65 seemed to be working fine, so I kept it for years, even after my restoration.ICEMAN6166 wrote:buzzing is indicative of the points inside malfunctioning.
Then one time, out of the blue, my battery overcharged and blew acid all over my restored front clip......
I agree with Brian -- there are some things that are improvements that should be accepted -- solid state regulators would be on that list.....
- Blackwaterforge
