gear ratio choice and questions
I have the stock rear end in my 65 lwb f100. I have an AOD installed and belive my ratio to be 3.20:1 i want more low end. thinking of 3.89:1 just dont know what bearing size, splines, etc. it is. Is there a way to tell before I tear it down?
Jim
_________________________________________
1965 LWB, Powered by 1993 COBRA MUSTANG engine with AOD trans and Under bed fuel tank.
Jim,
I believe our trucks were generally built with 28 spline rears.
3.73:1 would be the stock performance gearset for a 5.0 Mustang with an AOD - that should give you a little food for thought.
thanks greg. i am trying to figure out what the pinion bearing diameter is. I see all these different sets. some have a bearing on the rear of the pinion gear. some don't. i am pretty confused on this
Jim
I'd just look for a good 9" center section and swap it out. Should be pretty easy to come up with a 3.73 or 3.89 set from a yard.
That's right. Unless you want limited slip, you should be able to just find an old center section and swap it in.Greg D wrote:I'd just look for a good 9" center section and swap it out. Should be pretty easy to come up with a 3.73 or 3.89 set from a yard.
Of course, an awful lot of old iron is just getting melted down these days....
- dotcentral
Easiest way to go. Hit the pull-a-part type places and see if you can find a 6 cylinder truck, those usually had the steeper gear sets. You can get the door tag info here: http://home.earthlink.net/~threynolds2/ ... s6166.htmlfrdnut wrote:Agreed..That way if you don't like it you can always swap it back again..Greg D wrote:I'd just look for a good 9" center section and swap it out. Should be pretty easy to come up with a 3.73 or 3.89 set from a yard.
Assuming the pumpkin hasn't been swapped out and tag is on the door, easiest way too see what the potential donor truck has.
