instrument panel seal
66fordtrucknut
Post by 66fordtrucknut »
Alright, are you supposed to glue the seal on?it's so small I would think it would make a mess. It's been 6 yrs. since I had one, but I bought it and would like to put it on, Would've thought of would have fit a little tighter. It does okay around the top but when you get around the corner it pops off everytime you go to tighten it down. So glue or no glue and just deal with it (about tired of the later option)
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
realisticretiredone
Post by realisticretiredone »
I had good luck by taping it on from the back side. Clear packing tape was used.
realisticretiredone
cdherman
Post by cdherman »
IIFC, I used a tiny little bit of weatherstipping glue. Just enough to hold it at those points where its doing an inside curve and refused to stay put....
But the tape idea sounds better and less messy....
Once its been in there for a year or two, it gets stiffer and stay in place when you take the cluster out.
1683
Planned/considered upgrades:
Post by Gritsngumbo »
Thanks for the reminder. I took mine off when I had the instrument panel insert powder coated. Not a clue where it is now. Will have to take a look around. Wonder if anyone repops those?
66fordtrucknut
They must repop them, I bought it a couple of years ago and just found it. I bought from Tom @ flashback's. I will try the tape trick, really don't want the mess, CD I see you know the exact areas I was talking about, Thanks.
Charlie
62' SWB uni 223
f100matt
Post by f100matt »
Might be a dumb question, but I don't remember a instrument panel seal when I took my cluster out.. Where does it go? Between the instrument panel and the dash? What is the purpose?
-1966 Ford F100, 352, 4 speed, smoke grey, mustang buckets
-2003 Ford Ranger XL, 3.0, 5 speed
-1989 Ford F250, 460, highboy, 4x4
ezernut9mm
Sweden
Post by ezernut9mm »
yep there is a small balck rubber seal that goes between the bezel and dash and it is repopped.
6166 Junkyard Dog
Post by 6166 Junkyard Dog »
years ago when this seal was not available,, if you take a thin vacum hose and split it will work just the same
12649
Max
Post by Max »
LMC started carrying them a few years ago. I'm sure it has to be much better than their other rubber products.
Brian Taylor
Post by Brian Taylor »
I used a small vacuum line to make mine and it has worked fine.
1966 Ford F-100 LWB 300
66fordtrucknut
The tape trick seemed to work, it does finish off the dash nicely.
Charlie
62' SWB uni 223
matt2491
Post by matt2491 »
I just got rid of the seal. Doesn't bug me.
Just driving my truck.
wayne
Post by wayne »
Dennis Capenter has them
65 f100 swb
04 f150 FX4
95 jeep wrangler
Fanatic
Post by Fanatic »
I used a piece of door edgeguard. I didnt want the black line around the bezel. I used gray but other colors are available.
Tim
66fordtrucknut
Tim, I guess the black shows up big time against that yellow. Hasn't been one on the my truck since I bought it, now that it's on it looks good against the red.
Charlie
62' SWB uni 223
I seem to remember there being a small staple holding the ends together!,
I`ll have to re do Lenore`s some day!, as it hangs out at the bottom, I was waiting for a set of new cab screws and they came awhile back so it may be my next project!, I don`t think the black stands out too much Charlie! :D , old pic! :roll:
66fordtrucknut
Your right Alan looks good, Tim didn't like the black, preference I guess.
62' SWB uni 223
Fanatic
Post by Fanatic »
Just trying to stay away from the black and yellow thing. Gray/yellow is where I'm at
Fanatic wrote:Just trying to stay away from the black and yellow thing. Gray/yellow is where I'm at
