Can't get c6 to fit
- ethan_lanning
Can't get c6 to fit
So I just dropped a 390 in my 65 f100 2 wheel drive and I have the c6 sitting under the truck on a tranny jack but I can't seem to get the bellhousing between the crossmember and the cab? Is it just me or is there not enough room for the bellhousing?
Never poke another mans rust bubble.
http://www.supermotors.net/vehicles/reg ... 6959/57442
cut the rivets and remove the crossmember....or pull the engine out and put the trans back in. or my favorite way, pull the cab off, it's much easier to put in that way, you just need a lift or hoist.
- Alan Mclennan
Re: Hump
AH! Bugger!, that`s one thing I didn`t try in the fitting stage!bluebolt wrote:You are also going to need the C6 hump from a 67-72 truck.
but mine is a 351 Clevo!
- ezernut9mm
- Alan Mclennan
yeah!, I could decide where to put the lighter!ezernut9mm wrote:got a light mac?
- ethan_lanning
Thanks for the help guys...I just got done pulling the motor back out and installing the tranny from the front and got the motor back in and bolted up to the tranny
- Uncle Skip
Guys, a general thought on mounting transmissions.
On the automatics where you have a one piece transmission body and bell housing, use two grade 8 studs in the top of the motor so they can help guide the transmission in when you stab it.
For standard transmissions, use 4 grade 8 studs in the bell housing to help align the input shaft splines to the clutch disk.
The studs help hold the transmissions in place so you're not trying to align everything and hold it up in place at the same time.
U@ss
U@ss
wHEN PUTTING IN 1989 aod INTO 65 f100
WE DID THE SAME REMOVE THE RIVETS IN THE CROSS MEMBER AND REPLACE WITH GRADE 8 BOLTS.
ANOTHER MADE A >>GREAT<< SUGGESTION WHILE HAVING STRIPPED TO FRAME DO IT THEN.
Griffin GA 1965 F100
Have 3, one daily driver others in different state of repair/disrepair
- Alan Mclennan
Gary,so I could show how many holes the PO put in the dash!Truckrat wrote:Great idea Doc. I am going to do that on mine.
Alan, what ARE all those matches for? TR
