Well I say the hassle and time involved to do this conversion was WELL worth it, now I can drive like my wife, wait thill the last minute to brake!
QUESTIONS:
a) I used 1976 spindles along with all the tie end rods etc being 1976, WHAT year alignment specs should be used?
b) The fellow just set the toe in, but said that the camber and caster could be set by others by bending the I beams, your suggestions, your experiences
Front Power Disc Brake conversion done (QUESTIONS)
Griffin GA 1965 F100
Have 3, one daily driver others in different state of repair/disrepair
- banjopicker66
The specifications for all those years shouldn't change, as the angles are measure in degrees.
As for bending the I-beams, that takes a special shop, and is only rarely done.
I have found it much easier to change the spindles only, keeping the original I-beams. I think that when minor bends are made at the factory, or may have been made to adjust for a previous owner's accident, they may be imperceptible to the eye, but become an obvious problem when installed on another truck.
Jhewitt: See the link to HAMB thread in my post in thread (link below).....the fellow had his done @ a shop in Marietta, which is about 60mi from you, right??
http://fordtruk.com/forums/viewtopic.php?t=22472
HTH
James
HTH
James
THANK YOU, yes you are correct
I'll check it out
Where is the place located in Georgia??
I could not find the marietta post
marietta post on hamb.
http://www.jalopyjournal.com/forum/grou ... ionid=9079
1963 uni PATINA BLUE
1965 short bed
1965 short bed
- banjopicker66
