Are body mount locations different between a 65-66 half ton and a 73-79 3/4 ton chassis?
I think a 65-66 body would be fun on a 3/4 4x4 chassis.
Gen 4 body swap Q
Gen 4 body swap Q
1966 Mercury M-100
- ezernut9mm
as far as i know, 65 to 79 up to the back of the cabs are all the same. in 73 the frame width got 2" wider from aft of the cab to the back.
- Johnny Canuck
When I built my 4x4, it is a 66 on a 78 frame and running gear. I found the cab, and core support mounts to line up exactly. The only exception was the rear cab mounts were to high. I had to use spacers to make the cab sit level. Then I had to make mounts for the bed, because the frame is wider behind the cab.
fire truck
- Johnny Canuck
65TremecGT
