I have a question for Uncle Skip or anyone who has installed the Mustang tank like his article showed. In the article, it showed the breather line running over to the frame rail. Would it make sense to run it over to the frame rail and then forward towards the rear end housing? I was just curious if anyone had any leakage from fuel slosh under acceleration or having the front of the truck jacked up with a full tank.
Any help or experiences would be appreciated. I am in the process of starting the install. By the way, thank you for the article and pictures for us newbies.
Question for Uncle Skip/ Mustang Tank
1964 F100 SWB
2008 Mustang GT
1962 Chevy Belair 2dr Post
2008 Mustang GT
- Uncle Skip
The answer is yes. I ran the vent line to the frame rail and I did get sloshing and fuel spillage under acceleration. So I put an extra length of vent hose on and ran it up on the inside of the bed and that seemed to cure the problem. Just going forward won't do it because the liquid is being "pumped" and will shoot out unless it has that extra length to climb.
