Picked up a really nice, basically rust free bed. By basically I mean one small rust spot.
The square panel in front of the wheel well, driver side has a hole and is pitted pretty bad. Can this be removed and replaced WITHOUT removing the cross brace underneath? I can see that I'll need drill out the spot welds on the three flanges underneath, but the front is hidden or sandwiched between the brace and the front bed panel.
I don't want to just cut and weld a patch when the correct fix is to weld in a complete new piece.
Already welded shut all the stake holes and welded the rear seam completely shut and smoothed. This is the last fix before paint.
Bed Floor patching question
Lou
1965 F100 Short Bed
1965 F100 Short Bed
jefflovesf250s
I did same repair on my F250, both sides. Removed spot welds from above, cleaned x-brace and blew out accumulated mock, and fashioned new piece with correct flanges and space to replace seam seal. Welded from inside box. Looks factory.
