Trouble with air/foaming in power steering
LA 66
Post by LA 66 »
I finally got the front end aligned and the exhaust put on the '66. I've put about 100 miles on it.
Every time I drive it at highway speed for a few minutes the fluid foams up and overflows the resevoir. This does not happen at low speeds.
The system is the saginaw type from a '72 F100. All the components are new or rebuilt. There are no leaks (that I can find) and I've been through the bleeding procedure a dozen times.
Any ideas?
William in LA (Lower Alabama)
1966 F100 SB - 352/3spd
1965 F100 SB CC - sold
1966 F100 SB CC - sold
1966 F250 Work body - sold
1967 F100 SB CC - 360/C6 - sold
1971 F100 Long Flareside - 390/4spd - sold
1972 F100 XLT Ranger - 360/C6 - Gramp's old truck
Plus '53 CJ3B, '54 CJ3B, '67 CJ5, '70 Jeepster, '71 Jeepster
jamesdfo
Post by jamesdfo »
Care to describe your bleeding process?
The way I was taught as an autobody apprentice was to elevate the front wheels, then with the engine running turn it lock to lock a number of times, checking the fluid level periodically.
Also, depending on the year, the system could require power steering fluid, or ATF. And lord knows there are any number of different ATF's:):)
James
Isn`t the reservoir supposed to have a sealed lid? :?
deadheadno1
Post by deadheadno1 »
What ATF are you using? I strictly use Dextron (Mercron) type fluids because it has anti-foaming agents that the others don't have in them. secret.gif
LA 66
Post by LA 66 »
The fluid is type F. Bleeding procedure is wheels elevated, engine running, and turn the steering lock to lock.
DIXONBOY
Post by DIXONBOY »
On the new cars the make an adaptor to put a mighty vac on the resevoir so you can pull a vacum to suck the air out while you turn the wheel.
