C6 trans on a 352?
C6 trans on a 352?
I'm a new member from Henderson,Nv., is there acertain year C6 that will bolt up to the 352 in my 66 F100 lwb? Also I found a disc brake conversion kit from John's F-Fun Hundreds part #2020CB, I was wondering if anyone has any experience with this kit and what they thought of it.
66 f100 352,3spd; 2000 f-250 diesel
- Uncle Skip
Yes. They are all interchangeable and are great transmissions. The only thing you need to make sure of is that the bellhousing (one piece with the transmission case) has a round top. If there is a flat spot at the top of the bell, its not for a FE motor.
- ezernut9mm
they started using c6s when, in 68 or so? and fe's until 76 or so? so i would look for trucks in that age range.
