My turn signals blink very slow, way slower than my 71. I'm wondering if I replacing flasher if that will speed them up. Will a bad flasher cause them to be slow?
Different question, what is the # for the bulbs for the dash lights? How many bulbs in the "sweep" or non-round style speedo?
turn signal speed
- dotcentral
turn signal speed
Re: turn signal speed
dotcentral wrote:My turn signals blink very slow, way slower than my 71. I'm wondering if I replacing flasher if that will speed them up. Will a bad flasher cause them to be slow?
The flasher trips when it has a certain amount of current pulled trough it. If you have a bad bulb then you will have less current draw and it will take longer to flash. The wires could be going bad and that would cause more resistance = less draw = longer time to flash.
- dotcentral
All exterior bulbs light & flash. Interior dash lights are not working. One dash blinker (right one) flashes when either turn light is selected. Wiring could be bad, is probably original.
- DanSanDiego2000
Your "right" dash turn indicator is working properly. The Custom Cab dash (sweep, non-round) only had the one indicator on the dash on the right (where you would expect to see the "right" indicator). The indicator on the left of the speedo is for the high beams. So, left or right turn.... the right side blinks. High beam "On", the left spot glows red. Weird, but correct.
Regards.
Regards.
- dotcentral
