Page 1 of 5
MPG's
Posted: February 10, 2012, 12:19 pm
by BigMike
I filled the tank two weeks ago and again yesterday. I got 9.8 mpg on the last tank.
Re: MPG's
Posted: February 10, 2012, 12:26 pm
by Gritsngumbo
Re: MPG's
Posted: February 10, 2012, 12:29 pm
by charliemccraney
If that's around town, it's not that bad. A lot of idle time. They're not economy cars.
I've never checked my around town economy but I typically fill up once a week and it's usually about 12 gallons and I tend to go at least about 140miles a week. I try to drive economically so the way I typically drive, it may look like I only have a stock 223.
Re: MPG's
Posted: February 10, 2012, 1:13 pm
by Uncle Skip
MPG's? What are MPG's? We don't need no stinkin' MPG's. We have 3 carburetors. 8)
Re: MPG's
Posted: February 10, 2012, 3:01 pm
by foodstick
well I think the tired 300 makes around 12 in the Ltd Uni.... I know i used to hope for more.. But not knowing the background on the motors previous life ? i guess its what it is.
kid and I got it from his buddy for 50 bucks, and it had been laying in a barn for several years.. No idea on the history other than supposedly it came from UPS ? maybe out of a work truck or something.. I pretty much cleaned it up, changed the oil...and bolted it in ! people with a better ear than mine have said they think they hear some pin slap in one cylinder...
Re: MPG's
Posted: February 10, 2012, 3:08 pm
by BarnieTrk
BigMike wrote:I filled the tank two weeks ago and again yesterday. I got 9.8 mpg on the last tank.
What is your engine timing set at?
What brand of gasoline are you running in it?
What is the gasoline's octane rating?
What % of your driving is over 60 mph?
What % of your driving is under 50 mph?
For your 352-V8-powered, NP435 4-speeded, DANA 4.10 geared, 4,000+ lb (empty) F250 to get an average 10 mpg, I'd say you're doing PRETTY WELL! :clap:
BarnieTrk :steering:
Re: MPG's
Posted: February 10, 2012, 3:13 pm
by jkimbrel65
Uncle Skip wrote:MPG's? What are MPG's? We don't need no stinkin' MPG's. We have 3 carburetors. 8)
X2
Mike
Re: MPG's
Posted: February 10, 2012, 5:43 pm
by slick4x4
the 2 times i checked the MPG on my 61 was going to SlickStock 3 & 4
stock 4x4 truck with 223 and 4spd @ 55 mph ....... 13.5 MPG
and i have only 1 carberator... and it only has 1 barrell !!!! :twisted:
Re: MPG's
Posted: February 10, 2012, 6:00 pm
by oldtrucks
My 62 gets 13.5 also, its a bone stock 292 Y block with a granny 4 speed and I don't have a clue what the rear end ratio is. I have a 2.73:1 rear I am considering putting in it don't know if it would make much difference but it's worth a try I guess. I'm like Skip no more than it gets driven mileage isn't an issue. If it were a daily driver it would be some what of an issue.
Re: MPG's
by oldtrucks
Re: MPG's
Posted: February 10, 2012, 6:21 pm
by Toyz
The only time I've seen better than 12 mpg, OR 55 mph with my Uni, was downhill from Kansas. And that was on a trailer behind a 3/4 ton Chebbie :peepwall: The good part is I've had to only fill the tank once in well over a year!
Re: MPG's
Posted: February 10, 2012, 7:14 pm
by 62galxe
My 292 got a little over 13 on my slickstock trip at 75. :twisted:
Re: MPG's
Posted: February 10, 2012, 7:28 pm
by aarons428
WOW you get 13 mpg my truck gets about 4GPM hahahahahaha yes i said GPM I love it!!!!!!!
Re: MPG's
Posted: February 10, 2012, 7:40 pm
by oldtrucks
opps sorry for the double post must have fat fingered something.
Re: MPG's
Posted: February 10, 2012, 8:44 pm
by BigMike
What is your engine timing set at? 6*
What brand of gasoline are you running in it? BP mostly
What is the gasoline's octane rating? 87
What % of your driving is over 60 mph? 10%
What % of your driving is under 50 mph? 90%
See bolded answers above
Re: MPG's
Posted: February 10, 2012, 10:20 pm
my towtruck gets rated at gallons per hour
bored out 390, 4 speed, d70 posi rear d44HD front 4:10
today ran (plowed) 3.5 hours, and drove 4 miles on highway with 4 tire chains @12mph, 3 gallons used.
Re: MPG's
Posted: February 11, 2012, 12:50 am
by HiBoy63
The old knock on the Ford Fe was you get 10 mpg loaded or empty. We used to laugh about that when gas was just $1.00 a gallon. 352,360 and 390. This was a known fact they werent built for mpg just work. Lots of low end torgue med HP and bad mpg. I dont remember Mike did you have a 2 barrel carb. You might do better going to a 4 barrel and try to stay out of the back 2 barrels. That might help a little.
Re: MPG's
Posted: February 11, 2012, 1:50 am
by foodstick
Someone broke 20 mpg with a 352 on one leg of the trip to SS 1 !!!!!
Re: MPG's
Posted: February 11, 2012, 7:22 am
by DV65CustomCab
I get 15 mpg pretty consistently with my 352. What's killing the mileage in the O.P.'s truck is the 4:10 rear. You're never going to get anything higher with that ratio.
Re: MPG's
Posted: February 11, 2012, 8:39 am
by BigMike
DV65CustomCab wrote:I get 15 mpg pretty consistently with my 352. What's killing the mileage in the O.P.'s truck is the 4:10 rear. You're never going to get anything higher with that ratio.
Yep, that was discussed at length in another post.
I'd like better mileage but it isn't a DD. I'd probably drive it more if it got 14-15 though. It's depressing when you think of it as $0.36 a mile.
