anybody running a fan shroud on a 66 with a 460 ?
Looking to put a shroud on my 66 with a 460 , I see D3TZ-8146-C is a perfect fit for a 352 , just not sure if the inside diameter is big enough ?
1966 Ford F100 SWB
1966 Ford F100 Camper 4 x 4
2009 Ford F150 4x4
2009 Ford F150 4x4
Re: anybody running a fan shroud on a 66 with a 460 ?
i have a 66 with a 460 c6 and fan shroud . if your fans is too big get a smaller diameter fan until it fits the shroud. the 385 series and fe series engines fans will interchange. move the shroud up and down until it fits and change the fan spacer until it fits the opening without contact on the top or bottom of the shroud.
jim
jim
1966 F100 SW 428CJ C6
1965 F100 SW 428 TL sold
1966 F100 SW CVC 428CJ C6
1965 F100 SW CVC 428CJ C6
1965 F100 SW CVC 460PI C6
1967 F100 SW CVC 521 C6
1967 F350 390 4 SPEED
1970 F350 428 4 SPEED
1974 F350 428 4 SPEED
I have a lead on a 78 460 fan shroud , waiting for a reply back. I think it's a direct hookup on my 66 core support
1966 Ford F100 SWB
2009 Ford F150 4x4
2009 Ford F150 4x4
Is your 460 running hot? Check the plate behind the water pump impeller. Often forgotten. This is why 460 water pump kits have two gaskets. These gaskets look the same but are not the same. I use a 195 thermostat, big steel fan on a thermatic clutch and a stock FE radiator. No issues and I live in high desert Utah.
William-in-St. George
I have a 460 in my 66 with a 460 radiator and shroud from the 1977 donor truck.
My 460 is not installed yet , just an inexpensive way to control the air flow with a shroud.
Thanks 66camperspecial ! I read online that it's a pretty direct fit
1966 Ford F100 SWB
2009 Ford F150 4x4
2009 Ford F150 4x4
The radiator I have came from a F350 which had mounts like a 65 so when I got a better core support I got a 65,now I have seen those large 460 radiators with the 66 and up type mounts. The donor truck had a home made shroud so I picked up a factory shroud from a local junkyard.
