viewtopic.php?f=1&t=21420&
I wasn't kidding myself. I knew that alone wouldn't do it... and it didn't. It was mostly a cosmetic thing. In fact, I could tell no difference when it came to traction.
So, step 2, level it out.
I had lowered the front about 3" years ago, so it has a real hotrod looking rake. It looks cool but I don't believe it does anything good for traction. My method is to de-arch the springs. I left every leaf in, thinking that I'd like to retain much of the load capacity, if I want to haul something, which is likely, it's not a trailer queen show truck. This may not have been the best idea because the 3 helper springs are now in use at ride height. The ride doesn't seem too bad but time will tell. It's still a hair higher in the back but I just put the springs on and I think they settle a bit and I prefer that it be a bit to high than a bit too low. I'll get a more similar after picture of the whole truck.
I don't really like it as much as I had hoped. It looks more custom or lowrider (even though it's not really low) than hotrod to me and I'm a hotrod kind of guy but more so, I'm mostly a functional kind of guy, so if it actually does help provide better traction, I can live with it. Unfortunately, I probably will not find out until later in the year.
Some advice when dealing with old gunked up, rusty fasteners, whenever you can, clean the threads with a wire brush or a dremel with a wire brush attachment and then spray them with wd40 or a real penetrating fluid for weeks or months. If you do that, it should come apart pretty easily. Oh, and use 1/2" drive sockets and 6 point wrenches on bigger things. Patience and planning. It works.
Next, step three, traction bars... (hopefully within the next 2 months)
