SlickStock Swapmeet?
Next location of SlickStock
RickySlickUHS
Post by RickySlickUHS »
Will there be anybody there selling/buying parts? I've got quite a stock I could bring if anybody would be interested. And ya know... no shipping, :mrgreen:
I'd also like to take a look at what anybody else has got.
Didn't see any posts about this so I thought I'd ask.
Thanks!
Casey 65
Re: SlickStock Swapmeet?
Post by Casey 65 »
YES! Bring what you have to sell or trade.
ezernut9mm
Sweden
Post by ezernut9mm »
i will be bringing my junk.
Kid
Post by Kid »
JUNK, Ezer how can you call treasures junk
ezernut9mm
Sweden
haha, it always seems to be junk when you have it and treasure when you don't.
RickySlickUHS
Alright, I didn't know if that was taboo or not. I've got a trailer full I'll bring.
If anyone has anything special they'd like me to bring, shoot me a PM and I'll be sure to throw it in.
I need the cowl trim for one side, not sure which one will check!!
RickySlickUHS
Not a problem. For a 66 I assume?
I've also got tons of engines and transmissions. Everything from old flat-head v8's to 352's. You name it and I probably have it laying around somewhere. People don't like to pay shipping on big stuff like that so here's a chance to pick it up cheap.
Post by Gritsngumbo »
Alan Mclennan wrote:I need the cowl trim for one side, not sure which one will check!!
Pretty sure both sides are the same on the 65/66's (but not the 63/64's). I need one also :-)
ezernut9mm
Sweden
got a good running y-block?
RickySlickUHS
I've got at least 25 pieces of these trim parts. I should have what you need.
ezernut9mm wrote:got a good running y-block?
As far as Y-blocks I have a 312, which is a good core. Not locked, but I doubt it would fire right up.
I've got a 272 (which I will need to check the s/n to verify) that is also just a core motor.
I've also got a 292 that came out of a 55' 1-ton. I bought the motor on the pretense that it ran, but I have not verified this. It does look it though.
62galxe
Post by 62galxe »
I might be interested in the 312 core. Let me know how much.
1963 uni PATINA BLUE
1965 short bed
RickySlickUHS
62galxe wrote:I might be interested in the 312 core. Let me know how much.
PM Sent
slickmainer
Post by slickmainer »
Wonder what I could get past security on the plane
--Gregg--
you can't get there from here
PM Sent
2nd in line for 312
slickmainer
Are 312's that much better than a 292.
--Gregg--
At least 20" better. :-)
There were fewer 312's made which means they are harder to find (good or bad) therefore somewhat more desirable (to some).
62galxe
Post by 62galxe »
slickmainer wrote:Are 312's that much better than a 292.
actually theres a greater chance of getting a bad 312 than a 292. 312 had larger main journals and if the main caps were over tourqed the bolt holes in the block would crack. A .060 over 292 is a 301 so its only 11 inches better for me.
1965 short bed
ezernut9mm
Sweden
i'm looking for a cheap bolt in v8. that's all. pm me on the 292. thanks.
RickySlickUHS
From what I understand (and I may be wrong here) but all of the y-block motors are the same bore, they just have different rods, or maybe pistons, and heads to create the different cubic inches? Anybody able to chime in on this?
