https://sites.google.com/site/madmaxetc ... ge-upgrade
Questions...Comments?
Clutch & Brake Bearing, and Linkage Upgrade
Re: Clutch & Brake Bearing, and Linkage Upgrade
Pictures on both posts do not seem to follow link
Wow, what can be said besides you have turned an old hammered out piece of 18th century mechanics into a precision machine
Could you bend a small "z" into the rod going thru the floor to save the rubber?
You would have to do 2 Zs to run it through the floor in the same spot. But just using normal ends would do the same thing.
Some of the pictures follow the links, others don't...I will look into that.
I got them now. pop up window asks if I want to view only secure web content If you hit 'no' the pictures appear.
Great tips, thanks
Great tips, thanks
