Page 1 of 2
Fuel Float - Im keeping you guys busy
Posted: November 3, 2012, 9:20 pm
by bmcgc
My 66 has a new sending unit in the fuel tank. The PO told me the float has a hole in it and it is full of fuel.
Is the float replacable and if so, where do I get one.
Re: Fuel Float - Im keeping you guys busy
Posted: November 3, 2012, 9:38 pm
yes the float itself is replaceable not sure where to get new, i kept some used ones out of other tanks.
Posted: November 3, 2012, 10:06 pm
by foodstick
possibly patch it with JB weld?
Posted: November 3, 2012, 10:24 pm
by bmcgc
Will the float out of my 76 donor fit?
The donor has a new fuel tank so I was saving that anyway.
Posted: November 3, 2012, 11:10 pm
by foodstick
Its just a little brass barrel, if you can make it attach, and it floats, will probably work.
Posted: November 3, 2012, 11:16 pm
by Alan Mclennan
get a hold of a Plumbers soldering iron and just solder over the hole.
Posted: November 3, 2012, 11:23 pm
by totten
Dennis Carpenter has it.# c0az-9275-f brass float.
Posted: November 4, 2012, 8:41 am
by BarnieTrk
foodstick wrote:possibly patch it with JB weld?
Has anyone tried JB Weld?
I'm wondering if it would make the float too heavy to read accurately?
I'm not saying I think it would sink - as that would take quite a bit of JB Weld; but would the gauge read ACCURATELY with the float partially submerged more so that it normally would be?
BarnieTrk :dontknow:
Posted: November 4, 2012, 8:52 am
by 6166 Junkyard Dog
problem over the years is the float gets bounced around in the tank and thast the cause,, Unlike others I have seen sending units ones with a rubber shield on end so will not puncture a hole in it.........
Posted: November 4, 2012, 9:25 am
i have seen the rubbers on the end of the floats too.
a little bit of solder will not affect the float reading,
Posted: November 4, 2012, 10:07 am
by Toyz
You can certainly patch a 50 year old float if you prefer; it's not that hard to access. On the other hand, it's nearly fifty years old, the replacement is available and inexpensive; and probably good for quite a few future years. Replacement parts for ancient vehicles may or may not be readily available in the future, so I would at least consider having one on hand for the future, although other applications will work equally well.
As far as repairing results, if it will float, it'll work; the weight of the repair material will have extremely little effect on accuracy. Obviously the ones with the rubber diaper work just like those without, so the addition of a small amount of sealing material should have no effect.
Posted: November 4, 2012, 10:11 am
one trip to the junkyard and you could probably fill a bucket with good used floats.
Posted: November 4, 2012, 10:47 am
by Toyz
ICEMAN6166 wrote:one trip to the junkyard and you could probably fill a bucket with good used floats.
I've got too many buckets filled with parts already :roll: Pick a Part type yards around here are $2.00 to get in plus the price of the part, not to mention pulling the sender; Fresh tube of JB Weld is probably around $5.00. Certainly a friendly wrecking yard person would probably just hand you one if it were readily available. $4.95+ tax at your local parts counter? It probably won't say Ford, more than likely won't be American made, but it'll probably perform adequately for a bunch of years. You could also go to your friendly local Ford dealer and get the float; probably still made off-shore, but "genuine Ford" for about twice the coin.
I'm certainly in favor of re-using parts; I've made a pretty good living doing just that, but I'm thinking in this case my laziness would kick in, and I'd buy the part while the words to a certain very accurate James McMurtry song floated through my remaining brain cells.
Posted: November 4, 2012, 11:07 am
by Marty in PA
Heck just buy a new one from MAC's or Carpenter - cheap enough- about $5 plus shipping. By the time you mess around trying to fix the existing one or scrounge around for a used one you could have the new in and know it's good. No telling if a used one is any better then what you have now. :2cents:
Posted: November 4, 2012, 11:16 am
Marty in PA wrote: No telling if a used one is any better then what you have now. :2cents:
actually quite simple to tell, set it in a cup of water, if it floats its good.
Posted: November 4, 2012, 11:37 am
by bmcgc
I too have buckets of parts.
When I go to teh pick-n-pull I leave with fuses, light bulbs, circuit breakers, wire, fastners, and all the other little odds and ends that we always seem to need.
They usually charge me only $1 or $2 for all that.
Posted: November 4, 2012, 11:40 am
by Kid
Brian, When the one in my 64 had a hole in it I got the gas out of it and soldered it up and put it in water and it floated. I put it in the tank and it worked for awhile till it let more gas in it and it sank, took me 3 or 4 times of drying it out and soldering it and putting it back in before I got it right.If the hole is on top it will work till the gas sloshes around and gets back in the hole. Just buy a new one from LMC, DC or where ever you can get you one, you will be further ahead.
Posted: November 4, 2012, 11:48 am
by bmcgc
Will this one work, looks very similiar to me.
Summit is only 20 min away and I need to run up there anyway.
http://www.summitracing.com/parts/omx-1772901
Posted: November 4, 2012, 11:51 am
by Kid
looks like it will work, has the groove in the one end of it. Take your old one with you and compare..
Posted: November 4, 2012, 12:00 pm
AMC used Ford parts so im betting its the right one.
still like said take old one with you.
cant beat $4
