Hey Iam putting this 390fe back together....cam is in. now its time for the main caps. any advice on seal instal and type of ATV to use. I bought the black and the clear. I was told to put some between main cap and block surface to the outside of where the seals are. Im looking for some experience, I dont want to fuck it up.
Thanks always
Troy
main cap install: ATV to use???? Questions!
TroyPilcher
Re: main cap install: ATV to use???? Questions!
use the black and put only a very little along the top outer corners where the cap and block meet.
William-in-St George
Troy, FE main seals are easy to screw up. I'd go over to the FTE site and the engine forum and read all about these seals. I soak mine in oil and then install and I use black rtv on the ends and main cap corners. Like I said study this a bit before you do it. IMHO!
William-in-St. George
