engine swap in my 64
Posted: December 17, 2012, 8:47 pm
by rick64
Ihave just purchased a 1968 302 with a C4 auto behind it. I am going to swap in place of my 262 and granny 4 speed. i have found a coouple of places that are offering motor mounts for the conversion. My question is... Has anyone tried to remove the cross member that holds up the transmission? And moving it forward to hold a small block? If any of you have tried this. With or without success. Could you please speek up and let me know how it went. I am thinking of trying this myself. But if several of you have tried without success... WHy bother...
Re: engine swap in my 64
Posted: December 19, 2012, 2:56 am
by rick64
hello.... Not even an opinion???
Am I crazy for thinking this? I cant be the first to think of it. Anyone try this? Think its a good or a bad idea?
Help
Posted: December 19, 2012, 5:44 am
by Hunter's 64
http://www.speedwaymotors.com/Small-Blo ... ,3274.html
much easer to just get one of these, that way you can offset the motor to the passanger side as needed.
Danny
Posted: March 12, 2013, 12:33 pm
by Husker
http://www.speedwaymotors.com/1953-64-F ... ,1174.html
I am considering the same swap, has anyone used the item I listed above? If this is posted elsewhere forgive me as I am just finding my way around the site.
Posted: March 12, 2013, 2:06 pm
by unibody madness
I have that very cross member in my 61 uni long bed under a c6 that is bolted to my 460. Although I did not install it, it appears to work just fine.
I believe you have to take the tranny cross member out in pieces because of its width, I couldnt get mine out to modify it but sliding it forward or rearward should not be an issue and much stronger than the speedway one. I bolted mine back and torqued the bolts to spec.
John
Posted: December 13, 2015, 4:45 pm
by jalipke1124
My dad helped me engineer an engine crossmember and a tranny crossmember out of 6" C channel. Just be careful when welding it into place as I later found out that is where Ford stamped the VIN onto the frame.
