diesel oil
- therealjoeshmoe
diesel oil
will sae 30 diesel oil work in a gas motor with emission stuff... without hurting it..
Hunter's 64
Re: diesel oil
I run Shell Rotella in my jeep with a 4.0L fuel injected straight six , old motors with flat tappet cams like it because it still has some zinc in it , you should be fine, diesel oil's have more detergents in them and it will break down sludge if any is built up
Danny
Danny
- therealjoeshmoe
Re: diesel oil
cool i got a deal on some for my ford
Re: diesel oil
i use delo 15w40 in my y-block.
Re: diesel oil
TRJS,therealjoeshmoe wrote:cool i got a deal on some for my ford
I don't know where you located on the globe, but if you're going to use 30W motor oil in your Slick and you live in an area where it gets below 20*F, remember to allow the engine to idle (~1000rpms) and warm up some (a couple of minutes) before putting the spurs to it. I'd hate to hear you blew the oil filter off of your engine or similar badness........
BarnieTrk
- banjopicker66
Re: diesel oil
Diesel oil also has much more of the additives that prevent engine wear. You can (usually) go more than 10K miles on a "diesel" oil change, assuming the engine is in good shape.
It is really a waaaaaste of good money to change diesel rated oil at gasoline rated intervals.
If you do this on a regular basis, you can get oil sampling done that will guide you how long the oil will last.
- therealjoeshmoe
Re: diesel oil
man is january 29 and i woke up to 70 degrees this morningBarnieTrk wrote:TRJS,therealjoeshmoe wrote:cool i got a deal on some for my ford
I don't know where you located on the globe, but if you're going to use 30W motor oil in your Slick and you live in an area where it gets below 20*F, remember to allow the engine to idle (~1000rpms) and warm up some (a couple of minutes) before putting the spurs to it. I'd hate to hear you blew the oil filter off of your engine or similar badness........![]()
BarnieTrk
whats the thickness difference in 30 weight diesel oil and strait 30 weight gas oil??
i always used to run strait 30 weight in my ford...
i felt the thickness of the 30 weight diesel oil and it didnt feel any thicker than 30 weight gas oil...
i dont know bout yall but my truck take a lil bit to get warmed up, so i let it warm up a while before taking off...
- Blackwaterforge
Re: diesel oil
I use Delo 15W40 in my 300 6 cylinderICEMAN6166 wrote: i use delo 15w40 in my y-block.
Re: diesel oil
Sounds like you've got it going on....
Yeah, I also let my ol' workhorse warm up before putting the spurs to him.
So do you have any more info on the oil you've got? What type, brand, etc.
BarnieTrk
- therealjoeshmoe
Re: diesel oil
BarnieTrk
the oil i got is motorcraft sae 30 diesel oil.. xo30qsd
Re: diesel oil
30 is 30, gas or diesel.
- charliemccraney
Re: diesel oil
Do your research. I wouldn't put diesel oil in any of my gasoline engines because of the observations of a friend and engine builder with engines known to have been run only with diesel oil, and the resulting increase in wear. We're not talking overnight problems, but perhaps shaving 50K miles off of the life of an engine.
Any of the starburst oils of single viscocity (20, 30, 40, 50, etc) or dual viscosity 40 and higher (10w40, 15w50, 20w50, etc) should have plenty of the stuff required for flat tappet engines. I use Valvoline 20w50 gasoline engine oil with no additives and it has been great. When in doubt, consult the manufacturers spec sheet for their oil. There are plenty of gasoline oils that will do the job right.
- therealjoeshmoe
Re: diesel oil
NOW SEE HERES MY PROBLEM IVE DONE RESEARCH ON THIS ONLINE AND ASKED ALOT OF PEOPLE ABOUT THIS, PEOPLE EITHER SWEAR BY IT OR THEY SAY IT WILL RUIN A MOTOR.. WISH THERE WAS A POLE SOMEWHERE I COULE WEIGH OUT THE GOODS VERSUS THE BADS... SO WHY NOT MAKE THIS A POLE..
WHO SAYS IS WONT HURT YOUR MOTOR??
WHO SAYS IT WILL HURT YOUR MOTOR???
RESPOND PLEASE ONLY IF YOU KNOW WHAT YOUR TALKING ABOUT PLEASE....
JOEY
JOEY
Hunter's 64
Re: diesel oil
If you look at most of the common "diesel oils" you'll see they also are rated for gasoline use (SL, SM).
http://www.bobistheoilguy.com/forums/ub ... er=1483035
Danny
Danny
Re: diesel oil
me....
i run diesel oil in my combines
GAS engines built around 1970
they run full throttle pulling a hard load for up to 12 hours a day
for about two weeks straight harvesting wheat in 100* plus heat
in the fall i cut soybeans & milo for about a week and a half
i have never had any issues with oil problems
i run IH Case oil... its a high quality motor oil
me....
Re: diesel oil
I have run nothing but diesel oil in all of my cars and have done this for years. All are 60's era and they are all I drive - year round. Never had an oil related issue.
Re: diesel oil
I vote that diesel oil will NOT hurt your gas engine.therealjoeshmoe wrote:....SO WHY NOT MAKE THIS A POLE..
Ahh....er......I don't know if I know what I'm talking about.therealjoeshmoe wrote:
My opinion is only based on my personal experiences of running 15W-40 diesel-rated motor oil in my gasoline engines for years without any adverse effects.
Joey,
I'd suggest you grab up the the good deal on the diesel oil and use it in your Slick's gas engine and don't look back!
BarnieTrk
Re: diesel oil
15W40 Rotella is the best oil for flat tappet motors, been using it for several years... Never any issues
Hunter's 64
Re: diesel oil
loosrp wrote:15W40 Rotella is the best oil for flat tappet motors, been using it for several years... Never any issues
Thats what I run in my jeep 232,000 mile still runnin strong
Danny
- therealjoeshmoe
Re: diesel oil
ok ive made up my mind im running it!!!!
