Uncle Skip, HELP!!!!!!!!!
I saw the photo of your brake line/master cylinder installation with the in-line brake light switch. could you post that again?... I cant find it! Also, what T-fitting did you use? It looks nice and saves the railing around on the floor boards of the truck LOL
Will this help?
On this post - http://fordtruk.com/forums/viewtopic.php?t=2790&highlight=master
Is this link - http://fordtruk.com/index29.html
I agree it looks good there but just as another thought, mount it down below somewhere, use that tee as a "brake line union" to just plain hide it or clean up the firewall a bit???
Gerry.
Its been discussed often before, but the plunger switch is a better option than the pressure switch. The plunger lights up sooner, and even fractions of a second can make the difference between being rear ended and not being rear ended.
I have the plunger setup and you know where I am -- I have a welder, torch, and materials to do the job.
Let me know -- I'll be around this weekend if you want to look over the setup that I have.
Here is a pic. That assembly just clamps to the steering column. The connectors that I soldered on connect to the existing wiring harness with no cuts.
[albumimg]782[/albumimg]
David......
David......
What I also have, should you persist in the plan to use the pressure switch, is a new switch and the proper "T" blckk for it that I will reluctantly give you (reluctantly, since I'd hate to be responsible for your getting rear ended!!!!).
I have been out of town, though reading some email and visiting slick60s. Hadn't noted the Thouroughbread Ford hosting of a T-Bird event. Would be really nice if we could get them on board for next year. I plan to work on that.....
later....
later....
