All: I remember a discussion about correct way to cool 66 F250 COM transmission with new transmission fluid lines from transmission to rad, then auxiliary cooler and back.
That is, replacing the original design with waterlines from rad to auxiliary rad on side of transmission with fluid lines to rad/cooler and back.
I believe Uncle Skip made significant contributions to the discussion.
Can't seem to find it in a search. Has anyone got the link? Much appreciated. Jeff
Transmission cooling
jefflovesf250s
Re: Transmission cooling
this is the best way to route cooler lines. also remember if you use rubber line make sure it is rated for transmission use.
http://www.crankshaftcoalition.com/wiki ... ation1.jpg
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
c-6 wide ratio modified
torino front stub
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
