OK, on the continueing quest for part to swap over to C4 tranny.
I have automatic column coming I think, but I need the shift rod (linkage) that goes from the end of the column down to the tranny.
Anyone know of source for these new? Are they the same as for FMX, C6 etc?
And I am also in the hunt for the correct throttle kick down. I realize that Lokar makes an aftermarket one, but I figure that an original would be better. Anyone know if they are made?
Junk yards are so rare here......
Anyone know source for automatic tranny shift rod?
- Hoofbeat Racer
- banjopicker66
The shift rod is different, and it is based on the way the rod fastens to the shifter - both top at the column and bottom, at the transmission.
The '65 (possibly earlier?) up to '67 or '68 uses a shift rod threaded at the top. A square block threads onto this. It has a shaft which protrudes through the column shift lever, and is held on with a typical Ford spring clip.
The bottom of this rod is turned over, and pops into a rubber bushing on the transmission shift lever.
The '69 or so and later(I may be off on the dates) use a different setup. The top of the rod is turned over, and pops into the rubber bushing, which is in the column shift lever. The bottom of the rod is flattened and slotted.
At the transmission shift lever, a metal block with a shaft (a shaft like the one above) pops through a hole in the metal, and is held in place by s clip. The other side of this block is a threaded shaft, which slides through the slot in the rod. A nut secures the block to the shift rod.
When I went to a C-6, I used a '70 steering column and the later rod.
So, it depends on the shifter in the steering column, and the shift lever on the transmission, to determine which rod to use - or to cobble up out of two.
Hope this isn't too confusing, and hope it helps.
- banjopicker66
- banjopicker66
To somewhat answer my own question.
I found tonight that Lokar makes a kit, ACA-1801 that consists of an nicely adjustable billet shift lever and rod for C4 and C6 applications.
http://www.jegs.com/webapp/wcs/stores/s ... 6_-1_10519
For about $50 delivered, I am set to go. I realize that I might have been able to find one at some junkyard, somewhere, but here in KC, the pickings seem to be slip in my area.
