Can we find the flaws?
Cheers,
Jarrod
Jarrod
- Johnny Canuck
- mrcando_66F100
- YukonCor55
I only found one flaw...Driver's side hood spear is missing (look at the quartering shot from the right rear.) I wonder why he doesn't show any full on driver's side pics...hmmmm????
I don't know if I'd go $10k, but it looks like a darn nice truck!
SMSgt USAF Retired
I'd really like to know what sort of rust is hiding underneath. He painted it, but it clearly was NOT a disassemly, frame up job. In the one door shot, you can see a touch of rust comeing up below the lower hinge.
I'd be VERY careful before I dropped 10k on that truck. Could be its worth much more, could be just someone who made it look nice by covering up the rust.
Aren't the outside mirrors correct for 67-72? I can see a small bolt head holding the RF fender on at the bottom near the door. Must've damaged the old one when taking off the fender. If he painted the steering wheel and the shift collar and spruced up the engine he might get it, but not from me. Very nice truck though.
- banjopicker66
1. The gauge on the left looks like it is a vacuum gauge, which he notes in the text. Nice bright red needle (compare to speedometer needle) might indicate that he put new innards into original housing?
2. What in the world is up with 2 wires on each side of the coil? Is one for a hidden kill switch, to prevent theft by shorting out the juice to the coil? Is it for the "electronic ignition" he put in?
The 3 speed shifter ought to be a good enough theft prevention device.
3. I don't like the funky wiring sitting on the fender between the voltage regulator and the horn(?) relay. Ditto on the wiring from the coil to the distributor.
Not a 10K truck in my book.
norville wrote:mirrors, He's got west coast style there and holes for standard mirrors???
Alot of the time (maybe ALL?) west coast mirrors were a dealer ad on.
- YukonCor55
banjopicker66 wrote:1. The gauge on the left looks like it is a vacuum gauge, which he notes in the text. Nice bright red needle (compare to speedometer needle) might indicate that he put new innards into original housing?
The "2 wires on each side of the coil" are actually jumpers to the Pertronix ignition. You can see they go down to the coil. It's the easiest place to get the required 12V hot for the little module to work...unless you have a resistor wire in there, then it runs like crap!
It looks like everything is wired correctly but the work is sloppy. For $10K, that wiring should be wrapped up in a nice tidy package.
SMSgt USAF Retired
Pros:
Both hood spears are there, take a look at the back-to-fron drivers side pic.
If the rust in the lower door pillar seams is no worse than appears just some minor cleaning and some paint will fix it right up. Still a pretty nice truck as it appears.
Cons:
1.Be nice (considering these trucks) if he showed some underside shots too, cab mounts, torque box?.
2.My 64 223 has a red/orange rocker cover, blue?
3.I agree with Phil, why only do half the job?
Cons:
- ezernut9mm
shawns fords wrote:whats that thing above the radio on the dash? looks like some sorta funky cup holder?
looks like a nice pickup, im not a purist so, dont care about all them lil discrepeancies
dood, that's an antique gps system. i remember those from when i was a kiddo.
One pic does have the driver side spear, the other does not. The license plate shows expired sept 2006, so maybe its an older pic. Nice truck though, my guess is it will go up to $6500? Nice clean body to streetrod.
- banjopicker66
ezernut9mm wrote:shawns fords wrote:whats that thing above the radio on the dash? looks like some sorta funky cup holder?
I thought mabye it was a buoy buddy or something lol, I remember them from my 76 half ton, but never remember the compass (antique GPS) like that lmao
