disc brake spacer question
Is installing a 1/4" spacer sufficient to clear the wheel hitting the caliper problem on switching from drum brakes to disc brakes?
My Dad installed them on his 94 F150 to clear a set of classic turbine style wheels he put on the truck, worked for him. I spose it's worth at least a try, I seem to remember someone else here saying it worked too. Just keep an eye on your lug nut torque with them though.
- 6166 Junkyard Dog
WHAT I would look into is see how much clearance you have for the reason some calipers are pretty thick and can take a grinder to trim down, I did this on my 68 XLT To run 15" Charger Rallye Wheel with the Ford Caliper System ground enough after even putting a spacer with longer studs,, Please take your rotor to a machine shop to have the spacer custom made worth it in the long run
Now Cooper will try his best
Tom is right, turns out the calipers can be ground in a couple strategic places and then the stock rims fit.
Gerry, I have a set of 5/16 spacers that worked OK till I decided to grind down the high spots that Tom mentions. You can have em' if if you want. Or you can look and see where I ground to get the clearance. It wasn't hard.
