Slow posting
Slow posting
After noticing Uncle Skip's duplicate posts, it looks as if the problem is not limited to my computer.
Recently, it has taken an inordinate amount of time for posts or pm replies to make it to the outbox, then even longer before they actually are sent and appear on the forum. Is anyone else experiencing this?
Re: Slow posting
So this one posted quickly
Also, how did my avatar become hidden behind an "x"?
Re: Slow posting
That slow posting is beginning to be a PITA. If in fact posts, but doesn't show that it has, then if you hit submit again you get the "someone else posted before you posted this". And it's mine.
Re: Slow posting
Noticed it happened with Kid today, so hopefully a fix is on the way, or probably already done, since I have had no problem this evening.
- charliemccraney
Re: Slow posting
I've noticed.
Also, the "view new posts" no longer seems to work properly. That is, new posts keep adding to preexisting "new posts" which are days old or more at this point.
Re: Slow posting
I just did some database optimization - please let me know if the problem persists...
A clear conscience is the sign of a bad memory.
Re: Slow posting
Well - I answered my own question. When I posted above, it took F O R E V E R...
I'll pop open the hood and try to figger out what's going on...
Re: Slow posting
Thanks, JimDog, your efforts are appreciated!
Now, about that darned clock
JK,
Re: Slow posting
Still having problems with sending pm's.
Thanks,
Thanks,
