I have a slightly used radiator. I bought it new about 5 years ago, put maybe a thousand miles on it. truck dies so pulled it out. got rid of the truck, new owner was not interested in the rad. I pulled it out to list on craigslist and noticed lots of white granular deposits, sort of looks like large sugar granules. These are only seen at the cap neck, looking down at the tubes. Poured a little bit of white vinegar and water in it, let it sit for about 5 minutes, than ran a water hose over and flushed it till water went from slightly orange to clear. This removed some of the deposits, but plenty still can be seen.
What is this stuff? Lime?
Is there a cheap, safe, non-destructive way to remove it? Maybe a good flushing like using a prestone type kit mounted in a truck, with truck at operating temperature?
Thanks.
radiator deposits?
- dotcentral
radiator deposits?
- bobenhotep
Re: radiator deposits?
Scrape some off and do some "scientific testing" to see if they dissolve in anything. They might dissolve in clr, soapy water, who knows? Flushing it in a truck like you said might do the trick too.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
CLR usually will clean up such deposits. There is also a product I've never tried called "Skunk Rust". It is sold for rust removal and protection as well as radiator cleaning. It appears to be a phosphoric acid product.
A web search will reveal more information, although I have yet to see any actual reviews.
Dot most likely its Calcium deposits from the water not a major deal .
