Sugar,Sugar
Mr. Jones
Sugar,Sugar
Post by Mr. Jones »
Has anyone out there had any experience with sugar in their gas? If so what are the symptoms and effect to the engine?
bmcgc
Re: Sugar,Sugar
Post by bmcgc »
It should show up in the fuel filter. Remove the filter and poor the gas in a jar, if there is sugar you should see it.
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
1998 1100 Aero (Hers)
2001 1100 Aero (Mine)
Wish List:
Win Indy 500
Ask Elvis WTH he has been
Re: Sugar,Sugar
It WILL certainly clog the "sock" on the tank pickup. If it gets to an in-tank pump, it is likely to ruin it, just like any abrasive substance can. It can be an expensive procedure in either case, since the tank will require removal and cleaning. In the case of late model Silverados, there IS no filter, so one could only hope the sock caught all crystals.
On the unlikely probability it did make it to the injection system, the injector screens would most likely let most of the sugar through. There again, an abrasive is not something one wants in an engine, although urban legend has greatly exaggerated the effects IMO.
BTW, Casey , I'm not sure how the crystals would "sink" to the bottom of the tank, unless, of course, the tank was run dry :P
Paul Merrell
Re: Sugar,Sugar
Post by Paul Merrell »
My brother had someone put sugar in the tank and he drove his truck home 50 miles. The next day he tried to start the truck did not won't to start . When we did get it to start it had jacked the rocker arm studs out. We ended up pulling the engine and had to clean all the pistons and rings. Put it back together and never had a problem again.
Re: Sugar,Sugar
Must have been running that nasty ol' ethanol !
DV65CustomCab
Re: Sugar,Sugar
Post by DV65CustomCab »
Your friendly Slick 60s insurance adjuster is here to tell you the sugar thing is as presented on mythbusters. Just pretend it's sand; acts exactly the same. It will sit in the bottom of the tank mostly, clock the sock if there's enough of it, but generally is filtered out sufficiently by most fuel filters to not be a problem. When we have a verified claim, we simply have the fuel tank pulled, drained and cleaned out. I've had to buy the occasional in-tank pump (GM, no surprise) but that's it.
Stop The Longbed Hate! :)
Now: '93 F150 Lightning
Mr. Jones
Re: Sugar,Sugar
Post by Mr. Jones »
Thanks for info.Pulled and cleaned the carb yesterday,the bowl was clean.Will clean plugs and install later today.Hope I can get this truck back to work.66F-350w/300.
