c10 subframe??
c10 subframe??
Been gone for awhile I'm back thank god. I've been looking everywhere for c10 subframes installed on a slick but can't find any. Can someone help.
Pancho
Pancho
65 f100 with built 302 and aod tranny.
96 Chevy Caprice ex cop car.
2000 Escalade.
2000 Escalade.
- Brendan in NC
Re: c10 subframe??
Brendan Shane Dixon Greenville North Carolina
my collection all between 1964 an 1966
1. 1966 Ford F-100 Custom Cab Longbed 352 V8 3 speed 157,000 Original Miles (Same family since New)
2. 1964 IH Farmall 140 Offset Farm Tractor
3. 1964 IH McCormick Farmall Cub Offset Garden Tractor (Red Square Nose one of 2,345 Built)
Re: c10 subframe??
Yeah I know I got mine with all the brackets off for the twins so I'm just seeing what the Chevy c10 cross member looks like. I'm not interested in a car suspension or a little truck. No offense
2000 Escalade.
2000 Escalade.
Re: c10 subframe??
here ya go urquidezp.. this is my Boys Uni... he bought it already clipped but here are some pics of an 80's C-10 under it... going back with a Ford engine though...
http://i1118.photobucket.com/albums/k61 ... 4_0406.jpg
http://i1118.photobucket.com/albums/k61 ... 4_0408.jpg
http://i1118.photobucket.com/albums/k61 ... 4_0403.jpg
http://i1118.photobucket.com/albums/k61 ... sion1b.jpg
http://i1118.photobucket.com/albums/k61 ... sion2c.jpg
http://i1118.photobucket.com/albums/k61 ... nsiona.jpg
hope this is what you wanted...
Re: c10 subframe??
Yes Anthony thanks but I would like to see if anybody has just installed the cross member on original frame.
Pancho
Pancho
2000 Escalade.
2000 Escalade.
Re: c10 subframe??
Na no offense but I want a full size truck suspension under my full size truck. C10 looks straight forward.
Pancho
Pancho
2000 Escalade.
2000 Escalade.
fmartin_gila
Re: c10 subframe??
Not to rain on anyone's parade but for general info. All the years I worked as a Fleet Mechanic for a Utility Company, the most frame & suspension work was done on Chrysler(Dodge) pickups, then GM(Chev&GMC), and lastly the Ford pickups. The Ford pickup frames very seldom needed repairs when it seemed we were constantly fixing Dodge and GM Frames and suspensions. Of course all these pickups were used in situations that normal vehicles are never subjected to as vehicles are just another tool to get the job done to those guys and while working on the vehicles, we all kept the thought that we had to protect the vehicles form the abuses they would receive from the users.
Fred
Fred
luckystiff
Re: c10 subframe??
why so adverse to car or other truck suspensions? I said on the hamb and i'll say it here the jag xj is of similar mount design as the c10 but easier to swap in this case. and the jag was a VERY similar weight class at around 4000lb. I know the c10 is easier to find. if you intend to go low the c10 is gonna require sectioning or z'ing the frame or doing it as a full front clip.
And Dakota is NOT a Small/Little truck. it's closer to the same class as the f100....ken....
- theastronaut
Re: c10 subframe??
Porterbuilt posted on FB that they'll have an IFS front suspension ready in a couple months. If the budget allows it, it would definitely be worth the wait. Will be 100% bolt in.
thenephilm
Re: c10 subframe??
This is supremely irritating lol. Making my c30 front clip work on the front of my ford had been a lot of work lol. And now that that part is done, they come out with this clip ugh lol.
Hi I'm Justin.
Re: c10 subframe??
I bought a custom C10 drop member from Porterbuilt for my '66. Top notch quality stuff. Wish I would have waited for the ford version, but I will be building the rest of the frame for mine.
Re: c10 subframe??
I'll check them out
2000 Escalade.
2000 Escalade.
Re: c10 subframe??
i looked at installing a c10 crossmember in my unibody but the frame is wider on the c10 which makes it difficult to make the swap.
thenephilm
Re: c10 subframe??
The frame width wasn't the issue for me but the track width is kinda wide.
Hi I'm Justin.
Re: c10 subframe??
Is it wider than the crown Vic....
2000 Escalade.
2000 Escalade.
- ToughOldFord
Re: c10 subframe??
Why deliberately downgrade your suspension???
thenephilm
Re: c10 subframe??
On my build, I had to get the crossmember with the narrowed track width, narrowed the control arms, and had the wheels rehooped and the offset changed. It works great now but it was a lot of work. But I wanted the 1 ton 8 lug stuff on mine which gave me little option.
Hi I'm Justin.
- ToughOldFord
Re: c10 subframe??
What's up with the missing posts???
