how to make a 64 a 62
Re: how to make a 64 a 62
got the motor mounts done and then the tranny mount, just gotta drill some holes and then that's done...........but, the engine can sit in there without the cherry picker now....I'm happier than a puppy with 2 pee pees got the valve covers done too
1966 Long Box 5/8 ton
2000 Road King
2000 Road King
today was a GOOD day.....the front clip is sitting on the truck and finally got to figure out which doors to use. did you know that 64 hinges wont fit into the 62 openings? me either , anyway I got the fender patched up and it's almost ready to go back on, at least she looks like a truck again. also we got the dash put back together and I used the tip about the hole covers( for the knobs) from the hardware store, they don't look too bad, they are a brushed look, and the tank in too. now just waiting on some parts. Jeff
2000 Road King
2000 Road King
That's Good To Know. I Would Have Thought They Were The Same 61'-64' ..pikupmn wrote:did you know that 64 hinges wont fit into the 62 openings? me either
here's another piece of weird info...did you know that a 62 uses almost all fine thread bolts while a 64 uses coarse thread? me either, but I found out...when we tore down the two trucks ,we just threw all the bolts into a bucket and then had to go through them and sort them out .Jeff
2000 Road King
2000 Road King
Lookin' good. You'll be ready for Altoona early!
yeah Steve, looks can be deceiving, just getting everything test fitted for now, kinda ran into a problem with the tranny and going to have get another one .....unless someone has a input shaft for a pre 71 C-6, sorta rare trans but the right guy would want a tranny like this. still got a lot of little stuff to do also, just wanted to see how everything was going to line up what with mixing 2 trucks together, kinda like throwing it all in a pile and grabbing what you need out of the pile. Jeff
2000 Road King
2000 Road King
That's Good To Know! We Have A 64' & A 62' Now...........pikupmn wrote:here's another piece of weird info...did you know that a 62 uses almost all fine thread bolts while a 64 uses coarse thread? me either, but I found out...when we tore down the two trucks ,we just threw all the bolts into a bucket and then had to go through them and sort them out .Jeff
got the doors and front fenders pretty much where they need to be...........now for all the small tedious stuff that takes forever Jeff
2000 Road King
2000 Road King
2000 Road King
2000 Road King
2000 Road King
2000 Road King
That front end looks great! The grill stands out nicely! Enjoying watching/ reading your build progress.
Simon
65 f 100
65 f 100
thanks Simon that's the color scheme I want to go with ....satin black with Wimbledon white the pics look a lot better than the truck, she ain't perfect.
well............ she has a heart now, not beating yet but it's there all the same , the front clip is in place all I have to do is button up the trans and a few other things.........still got a lot of wiring left tho, and me and electrons don't get along so well. gonna put my electronic ignition on tomorrow. Jeff
2000 Road King
2000 Road King
well, it's been awhile since I've posted, so here's an update.....been doing all the piddly-assed stuff that takes forever, like tranny lines, radiator, seat, made the pieces that go around the steering column, got the dash in and realized i forgot to put a piece in( i'll get it later), hitting the junk yard, trying to do stuff that's not costly, at least till I go back to work and get some money. still need to get my driveshaft cut to size, get exhaust, and I have to order a TV cable for the tranny. so that's where I am...............here's some pics, Jeff
2000 Road King
2000 Road King
SHE'S ALIVE!!!!! finally got the ol' girl fired up the other night. about 8" of exhaust on each side , but, I got wood . also fixed the instrument panel and had to redo the steering column. here's another little difference between a 64 and a 62.....the steering columns are different as well as all the inner workings. whoda thunk? Jeff
2000 Road King
2000 Road King
Glad to see the progress! You'll be terrorizing North "O" within a week. Better get to humpin', spring is here and you'll have to go back to your real job.
nah, got to get a drive shaft built and exhaust yet, lucky me, I went back to work today YEA
2000 Road King
2000 Road King
I've driven around North O with open headers, you don't need exhaust! Of course that was in '75-79!
Enjoy work.
Enjoy work.
got the ol girl to move under her own power today , finally got the driveshaft made and all the linkage stuff for the AOD hooked up........had to add a gallon of tranny fluid and she'll light "em up....YEE HA. still gotta get exhaust work done cause she's pretty loud (or so my neighbors say ). hell I might even get a poor boy paint job on it b4 Altoona. guess we'll see. Jeff
2000 Road King
2000 Road King
well got the headers on the way and license plates today, had to put the bent-assed bumper on the front, gotta run a front plate so the cops will leave me alone(i hope), gonna run around the "hood" with open headers till i get everything tuned in, hope i don't piss off the neighbors too bad. i don't know what kind of paint someone used on this thing b4 but that stuff is hard, 50 grit doesn't do alot of good, comes off like powder coat but it ain't. Jeff
2000 Road King
2000 Road King
Wow, its coming along.... I think I will be seeing this one in person soon.
