Anti Rattle Window Kit
Got my anti rattle window kit for the 64. No instructions were included. I'm not sure what the sequence if installation should be. It seems to me that you would do the wing window first, the divider, the upper window channel then the lower seals. I will have all the inside parts out, cleaned and lubed and the inside of the door cleaned out. Should I coat the inside of the door with some sort of rust preventative? Any advice out there?
on a 74 chassis, 390, C6
A work in progress
A work in progress
Re: Anti Rattle Window Kit
best advice i could give ya is remember the sequence you took it apart and reverse it, the first door will take twice as long to put back together as the second. Good luck.
here's one…
viewtopic.php?f=5&t=26739&hilit=a+new+w ... stallation
And pics of removal from one of the forum members.
http://www.supermotors.net/registry/17895/69956
Good links .... thanks
Nic
Nic
In Carpenters book, they had pics of some of the install.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
and I'm thinking they have a video on their website? If not they do have the instruction along with pictures.64 f100 wrote:In Carpenters book, they had pics of some of the install. Rich
Thanks much. With the removal pics and the installation link it will be much easier I'm sure.Leeroy wrote:here's one…
A work in progress
A work in progress
I'll look for that too. Thanks.64 f100 wrote:In Carpenters book, they had pics of some of the install.
A work in progress
A work in progress
