Trouble removing old undercoating
I was having trouble removing the thick old undercoating from the underbody of my '65. Igot out my multitool with a flat blade worked great, not effortless but better than anything else I tried. Hope this helps others who are struggling with removing undercoating.When I mentioned multitool, it's electric with vibrating head for cutting & sanding. Mine is Craftsman I'm sure there is other brands. You can usually buy them pretty reasonable with all the attachments. Hope this helps.
Re: Trouble removing old undercoating
It will either fall off, or hang on like a son of a gun, I have used scrapers,screw drivers, and gasket remover tools. I know some people use a torch to soften it as it goes...
We used to try a lot of things years ago when building stock cars.
Torch and putty knife, messy but fairly easy. Smells bad, fills shop with smoke.
On something like a floorboard. Put dry ice on it. Let it sit for a while and smack the floorboards with a big dead blow hammer and watch it fall off, sweep up the pile. I have seen one hammer blow clean off the entire left half of the floorpan on an '86 t-bird unibody. I've also seen it have absolutely no effect at all.
Fun stuff,
Fun stuff,
