What size are the holes in steering wheel for pulling it?
I think the subject about says it. I tried all over to find the answer by searching.
I have a steering puller and the bolts seemed a little tight, but I figured it was just crud, so I horsed them in a little ways, but not too far.
And then they pulled out when I gave the puller some torque.
So, I either used the wrong bolts or I didn't put them in far enough. In any case, I need to chase the threads with a tap and try again and I want to be certain what size is correct.
So who knows?
Thanks fellas.....
So who knows?
Thanks fellas.....
- FORDBOYpete
Great. Too bad the hardware store is closed. I buggered the bolts up as well, so I am going to chase the threads in the holes and find some nice new bolts tomorrow, and perhaps I can get that bugger off. Tried beating on it a little, but that was fruitless and I was afraid I'd mushroom the shaft (yes, I had the nut backed off, so that it would protect the threads, but even so, it wasn't moving.......
The wheel in question is from a column that I liberated last week. The wheel is in decent shape, so I hate to ruin it with my inept techniques.
- ezernut9mm
i have a universal puller with three different sets of bolts if you want to use it. it worked for my 76 f150 and should work for your application.
Interesting...
Since Pete's post, I went out and chased the threads with a 5/16x24 tap. Worked fine.
Then I looked at my "universal puller". It did not have 5/16x24 (fine) bolts with it. Does yours?
I wonder how many other folks have threaded a 5/16 coarse (which is what my "universal puller" came with) and got the wheel off and just assumed that the threads were getting a little old.
I recall now that I had some trouble with taking a wheel off 4 years ago as well, when I originally bought the set.
It should be cried from the mountains that ford uses a 5/16x24 bolt and that at least some "universal pullers" ain't very universal.......
You learn new stuff all the time......
Thanks for the offer -- I think I am all set, except for a trip to the hardware store.
After that all I need is the wiring harness plug and bracket that holds it all to the dash. Fraid I'll need to do some junk yarding for that stuff.
- FORDBOYpete
FWIW Dave,
I replaced all my "pulling bolts with A&N if I can find 'em long enough, otherwise I use grade #8s. But all the bolts that come with those Univ Pullers are soft & stretch or strip at some point. Since Bolts are cheaper than Strg wheel hubs I've been collecting bolts as I go along & haven't hurt a threaded boss in years now.
Another hint is use a thick stainless washer between the pull bolt head & your puller & you won't gore or gouge it up. . .
Also I've learned to tap the holes out before I try to thread anything into them, I have a bottoming tap, but a regular 5/16X24 with the taper ground off will work just fine. Pre Tapping is critical to me, 'specially on the Older ones. You don't want to know why I have come to go through all that, or perhaps you already have a good Idea and almost do know.
The other thing I have learned is lubricate freely B4 threading in!
Once you have good tension on the bolts by tightening the center bolt, take a 16 or 20 oz Ballpeen & give center pressure bolt of puller a "smart" dead blow, whack on the top. The wheel should "POP" loose right then.
Metric Wheels give me fits, my industrial Fastener supply house always
"Raggs" on me when I come looking for wierd metric bolts for doing stuff like this. . . .
FBp
FBp
Change is the Only Constant
The wheel came off nice and smooth this evening, with the correct 5/16x24 bolts.
Unfortunately, the PO had removed the wheel once with a hammer and the end of the steering shaft is mushroomed some (no, I did NOT bang on it that hard).
Oh, Pete, great guru of all things Ford, tell me what the threads are on the steering shaft so can get a die and clean up those threads as well. They are fine for sure, some sort of "really fine" Grrrrrrr...
- FORDBOYpete
Dave, I'm not really sure, except I know it's a Standard, NFT type, machine thread.
If you have a local "fastener jobber" or Nut, Bolts & Screws store walk in with the
Nut and have them check it with a thread gauge.
You'll probably need to buy a die that size anyway. .
I would guess it's a 3/4 NFT (National Fine Thread), if I had to tho.
FBp
FBp
- 6166 Junkyard Dog
I use the bolts that holds the fan blade/spacer on which is 5/16 fine thread
Now Cooper will try his best
- 66fordtrucknut
