Alan Mclennan wrote:Nice work Kev!, you don`t sleep much do you!
Alan, I try not to sleep, it isn't very productive.
aarons428 wrote:Just remember the bigger the "tip" the louder it will be!! Ask me how I know!!
Even at the back of the truck, it will be louder??
randyr wrote:kstones63 wrote:I had figured that I would put the license plate on a slide to come down when the key turns on and goes away when it turns off but AZ has a law that says that the bottom of the plate has to be at least 12" above the ground so that might be a problem.
Kevin
Look at my post in this thread on Feb. 16......
Randy, With the truck as low as it will be, the license plate will probably be less than 12" above the ground with those brackets. I will have to get it back down on the ground, get it set to final ride height and check it at that time.
I really don't want to inset it in the tailgate. Looks to much like an import truck.
Kevin
