Thanks for the help, seems my F100 did in fact come with a 352 in '66! I have been told by several people that I have a 390 but my engine tag claims a 352. Is it possible to determine the difference visually? Ignorance is not bliss!
Thanks,
James
How to identify 352 & 390
- FORDBOYpete
Not externally visually, but you can remove the spark plug on #1 with the cyl @ TDC Position insert a rod or dowel, mark a point on it, say the plug's gasket seat.
Next rotate the crank 180* and re-mark at the same reference spot while crank is at BDC.
Then measure distance between high & Low marks to determine actual engine stroke. From that you will be able to determine the CID of the engine.
Oh BTW, Welcome to our Slick 60's site, & the Truck Talk Forum, James
FBp
FBp
Change is the Only Constant
Eh James,welcome to the site/board.
I just live over the Malahat in Shawnigan Lake.
I have 5 or 6 slicks and lotsa parts.
Drop me a line and come on up for a visit.
-Shiny
-Shiny
every movie I've seen the bad guy in the Camaro outruns the cop in the Crown Vic everytime!
'66 Merc "Crewlcab", SWB, clipped, c-notched etc
'65 Merc extra-cab,soon to be 3/4ton 4x4 SWBSOLD
'66 Merc J-Lo and Redford movie truck, from the movie "an unfinished life"
'66 Merc Crew Cab project 4x4 Cummins!
'65 Chevy crew cab
'65 Chevy crew cab
